View Poll Results: Color?
Voters
3. You may not vote on this poll
  • White
    0 0%
  • Black
    2 66.67%
  • Blue
    0 0%
  • Red
    1 33.33%
Multiple Choice Poll.
Thread: Plasti-dip Questions
Results 1 to 16 of 16
  1. #1 Plasti-dip Questions
    SE Level Member Justinm1700's Avatar
    Oct 2015
    Fargo, ND
    Okay, so I'm ready to dip my car, but I have a couple concerns.
    1) Can I just use regular paint thinner with plasti-dip
    2) How many gallons do I need to cover the whole car well?
    I was thinking I would use 2 gallons of dip, and 1 gallon of thinner (3 sprayable gallons)
    3) Should I just do this in my garage, or drive back home (2 hours) and dip the car in the shop.
    I want to get this done before winter hits so it can take a good week to set.
    ALSO! Blue, red white, or black??
    Thanks!
  2. #2 Re: Plasti-dip Questions
    Dec 2010
    DMV
    Subd
  3. #3 Re: Plasti-dip Questions
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Black
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #4 Re: Plasti-dip Questions
    Non! Keep the original paint and address any problems
    04 Comp G.
  5. #5 Re: Plasti-dip Questions
    Oct 2015
    Fargo, ND
    I'm glad none of these replies help me with anything...
  6. #6 Re: Plasti-dip Questions
    Jan 2013
    leavenworth ks
    Black and which ever garage is the cleanest.
    Sent from my SM-S820L using Tapatalk
  7. #7 Re: Plasti-dip Questions
    Oct 2015
    Fargo, ND
    [QUOTE=Travisgt2;1390522]Black and which ever garage is the cleanest.
    Do you know how and if I should thin the plasti-dip?
  8. #8 Re: Plasti-dip Questions
    Dec 2008
    Lawndale, CA
    You could probably find all that info here
    https://www.dipyourcar.com/
  9. #9 Re: Plasti-dip Questions
    Oct 2015
    Fargo, ND
    I've definitely checked, there's nothing. It's a preference thing, but I've never done this, therefore I have no preference.
  10. #10 Re: Plasti-dip Questions
    Jan 2013
    leavenworth ks
    Thin it yes how much no
  11. #11 Re: Plasti-dip Questions
    Dec 2010
    DMV
    No thinning required. I've dipped a few cars and no thinning was needed
  12. #12 Re: Plasti-dip Questions
    Jan 2013
    leavenworth ks
    Well there you go so three gallons straight
  13. #13 Re: Plasti-dip Questions
    Oct 2015
    Fargo, ND
    Well what's thinning really do, then? Does it just make more sprayable product, make for a smoother coat, easier to clean the gun after?
  14. #14 Re: Plasti-dip Questions
    Nov 2012
    Madison
    Xylol/Xylene is what you use to thin it.
    IIRC >>>> it comes ready to spray in the gallon size....already thinned
    You can thin it in the gun or spray Xylene after to smooth it.
    I used spray bombs on a raw deteriorating clear coat Corrola hood. I didnt prep at all except for a quick wipe with Meguiars rinseless wash (D114).
    I should have sanded lightly to smooth it and wiped it clean probably with Xylol to get rid of oils.
    So step #1 is PREP
    after fiddle fckn with spray bombs. the wet spot is dry on the passenger side. It started getting rough and bumpy. Xylene smoothed everything out.
    It also accidently ran over a headlight and melted it. It will destroy plastic.
    after smoothing with Xylene,,,,,,I am still impressed with my headlight resto. those things looked like cardboard before.
  15. #15 Re: Plasti-dip Questions
    Apr 2015
    Fl
    I would not plastidip the entire body because it is a PITA to clean and maintain.
  16. #16 Re: Plasti-dip Questions
    Aug 2013
    McDonald PA
    Quote Originally Posted by wezl3ym View Post
    false. When done properly it isn't.
  1. Plasti-Dip GP
    By turoalyse25 in forum General Grand Prix Discussion
    Last Post: 12-18-2014, 01:51 PM
  2. Plasti Dip
    By Dmichaels in forum General Grand Prix Discussion
    Last Post: 01-07-2014, 01:36 PM
  3. Plasti dip?
    By Kcgp in forum Introductions/Noob Questions
    Last Post: 02-23-2013, 01:46 PM
  4. Plasti Dip
    By GrandPriest24 in forum Introductions/Noob Questions
    Last Post: 01-31-2013, 11:09 PM
  5. Plasti-Dip....I need help
    By danielle15 in forum Off Topic Discussion
    Last Post: 04-06-2012, 11:50 PM
