Thread: trouble codes
Results 1 to 7 of 7
  1. #1 trouble codes
    Apr 2008
    Chillin at the Beach , VA
    Could it be possible to start a trouuble codes section so any information on this area could be put there. It would be easier for anybody getting a code to find what they are looking for to help solve their problem. Just a suggestion to see what everyone thinks.
  2. #2 Re: trouble codes
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: trouble codes
    TDCRacing
    Guest
    I think he meant more like this.
    2001 GTP-Was getting a p0300 misfire code-Car bucking/studdering only at high rpm's- Turned out to be a bad coil pack.
    I think it would be a good idea. That way we could have specific info on what it was exactly that was causing the problem in this case, That way it would pertain more to our cars instead of a list of 12 things that usually causes this code to be set.
    I myself have access to all the trouble codes available for my car via my tuner. And a scanner to help me aid in finding the problem. Still can't
    Maybe a trouble code sticky could be started in the tech section.
    I am having a DTC right now and I cant for the life of me figure out what is causing it. Had to brose through the fourms and finially saw someone that had the same problem and am awaiting an answer from them to see if the problem was ever fixed since the post was not updated stating if it was or not.
  4. #4 Re: trouble codes
    Oklahoma
    I wanted to do something similar to this some time ago but I couldnt get much motivation for it so I kinda let it go. But I would love to see some type of troubleshooting database here. You cant make it comprehensive of course but you could make it a very good starting point.
  5. #5 Re: trouble codes
    GTX Level Member webracin's Avatar
    Arkansas
    How about adding them to the How To section on the board, then if we get alot of them I can move them out to there own section? Kind of like we did with the Cars for sale. Once we got enough of them, we moved them to their own section.
    One thing I would ask is that we keep it uniform in the title.....
    P0300 - Misfire bla bla
    Then in the body of the post put the year and make of the car - symptoms - Fix
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  6. #6 Re: trouble codes
    Apr 2008
    Sounds good. I'll see what I can dig up to get this thing started.
  7. #7 Re: trouble codes
    Oklahoma
    Yeah, I would like for us to all settle on some type of template or format to use if we do this as it will make for easier organization and searching. Chris, if you have some ideas hit me up in an email or something when you have time and we can hash out something then put it on the board and see how everyone likes it.
  1. OBDII Codes [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-26-2011, 01:23 AM
  2. trouble codes.
    By hotshot in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-11-2008, 06:58 AM
  3. ses codes and car cutting out
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 12:33 PM
  4. ecu codes ??
    By sal3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2008, 12:48 PM
  5. clear codes
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2008, 10:12 PM
