Thread: *Added* Shift Kit, 4th shaft, sprags, Oil pan, gaskets, Dogbones, & More!
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 100
  1. #1 *Added* Shift Kit, 4th shaft, sprags, Oil pan, gaskets, Dogbones, & More!
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    I have a few GM side cover gasket kits for our transmissions. These things are $60-80+ from the dealer. Selling for $35 shipped Send me a pm or email greg.stefan@gmail.com if interested. Thanks!
    All prices are plus paypal fees.
    *TransGo Shift Kit. Brand New, unopened. From TEP. $45 Shipped
    *<10k mile factory timing chain and tensioner. (no gears) bought for different build, then decided to go turbo. $15 shipped.
    Bead Blasted dogbones, stock length $30 Shipped
    NEW GM steel oil pan $50 +shipping
    Set of very low mile ratcheting sprags for 4t65e Transmission $65 shipped
    Hardened 4th clutch shaft $55 shipped (1 sold, one left...)
    GM Engine Sealant RTV - like ZZP sells, new unopened tube $10 shipped. (10+ available)
    4t65e Trans Filter in pan - OE filter, NOT an aftermarket one $25 shipped.
    OEM GM Valve cover gaskets. Have a few sets, some SC some NA $20 a pair shipped let me know which style you need
    I have some other random trans parts and grand prix parts so if you are looking for anything specific lmk. Have some oe clutch kits, wiper park mechanisms, oe front calipers $40/PR +shipping, gray GTP badges $30/pr... may have more. Shoot me offers for now, will update some things with prices as I go
    L26 Upper and Lower intake manifold. $OLD
    3000 stall converter from Dynotech (built by ProTorque) <10k mile (258mm) 3800 supercharged l67 - No need for drilled flexplate or worries about converter clutch issues! $OLD
    WBS Red poly mounts set of round dogbone mounts (BNIB) $OLD
    Poly upper motor mounts in brackets (black square ones) $OLD
    Intense lightweight pushrods 7.050" $OLD
    ARP Main Studs NEW never installed, not in box $OLD
    HV3 insert for l36 intake manifold $OLD
    HV2 - setup for use in l26 intake $OLD
    Front cover with machined oil pump cover (&pump) for rollmaster double chain. $OLD
    LS7 lifters, low miles approx 12k IIRC, excellent condition $OLD
    Also have 4 NIB LS7 lifters from the GMPerformance 12499225 kit $25 shipped $OLD
    Rollmaster double timing chain set 15k on it $OLD
    97-03 OE grille inserts new in bag $OLD
    Brand new in box Innovative Turbo 54mm compressor wheel with polished E cover(3" in, 2" out). T3 exhaust housing with 5 bolt outlet, .63AR and stage 4 exhaust wheel. Was originally the base turbo for the z7 kit from zzp, bought from Matt (Stattama) but I think I would like to go just a little bigger. Willing to work with trade of precision 6262 or similar 5bolt outlet preferred. $OLD
  2. #2 Re: 4T65-E Side cover gaskets, Rollmaster, L26 UIM, sprags, ARP main studs & more!
    Lorain, OH
    TTT - Added pic of rollmaster
  3. #3 Re: 4T65-E Side cover gaskets, Rollmaster, L26 UIM, sprags, ARP main studs & more!
    Lorain, OH
    Bump - Pics of grilles
  4. #4 Re: 4T65-E Side cover gaskets, Rollmaster, L26 UIM, sprags, ARP main studs & more!
    Lorain, OH
    nobody needs any of this stuff?? not even a rollmaster double chain?
  5. #5 Re: 4T65-E Side cover gaskets, Rollmaster, L26 UIM, sprags, ARP main studs & more!
    Lorain, OH
    ttt
  6. #6 Re: 4T65-E Side cover gaskets, Rollmaster, L26 UIM, sprags, ARP main studs & more!
    Lorain, OH
    new year bump.. added hv2 set up for use in l26 uim
  7. #7 Re: 4T65-E Side cover gaskets, Rollmaster, L26 UIM, sprags, ARP main studs & more!
    Lorain, OH
    TTT sold rollmaster, added front cover with modified pump cover
  8. #8 Re: 4T65-E Side cover gaskets, Rollmaster, L26 UIM, sprags, ARP main studs & more!
    Lorain, OH
    BUMP, added lifters
  9. #9 Re: 4T65-E Side cover gaskets, Rollmaster, L26 UIM, sprags, ARP main studs & more!
    Lorain, OH
    TTT added pushrods, sold grilles. Anyone have 3/8" 7.000" long pushrods for sale? Need a set
  10. #10 Re: Trans parts, Pushrods, Front cover asm, L26 UIM, ARP main studs, LS7 Lifters, HV2
    Dec 2012
    South Padre Island, Tx.
    20 shipped for the four ls7 lifters?
  11. #11 Re: Trans parts, Pushrods, Front cover asm, L26 UIM, ARP main studs, LS7 Lifters, HV2
    Lorain, OH
    ttt
  12. #12 Re: TURBO, Trans parts, Pushrods,Front cover, L26 UIM, ARP main studs, LS7 Lifters, H
    SE Level Member boosted98's Avatar
    Jun 2010
    ohio
    I might be interested in the cover...what exactly is done to it???
  13. #13 Re: TURBO, Trans parts, Pushrods,Front cover, L26 UIM, ARP main studs, LS7 Lifters, H
    Lorain, OH
    has the machined oil pump cover so you can run a rollmaster double roller chain without rubbing on the oil pump. Other than that it is a factory cover. Comes with the oil pump that was in it when I got it. I just ended up going a different route so I don't need it.
  14. #14 Re: TURBO, Trans parts, Pushrods,Front cover, L26 UIM, ARP main studs, LS7 Lifters, H
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    1 " chain ? lol
    Worlds Smallest Dick Award Winner!
  15. #15 Re: TURBO, Trans parts, Pushrods,Front cover, L26 UIM, ARP main studs, LS7 Lifters, H
    Lorain, OH
    I wish I had one of those.. I would be keeping it though ZZP is working on their own version. Just got the prototype in last month but they said they were having issues with the splines fitting their input shafts. Supposedly going to be priced "well under a grand" according to Zooomer. Fellow upstate NY'er! Didn't think there were any other turbo Grand Prix's around here. What turbo are you running?
  16. #16 Re: TURBO, Trans parts, Pushrods,Front cover, L26 UIM, ARP main studs, LS7 Lifters, H
    Lorain, OH
    Bump
  17. #17 Re: TURBO, Trans parts, Pushrods,Front cover, L26 UIM, ARP main studs, LS7 Lifters, H
    Lorain, OH
    TTT lowered some prices
  18. #18 Re: 3k converter, Pushrods, Front cover, L26 UIM, ARP Main Studs, Trans Parts, HV2..
    Lorain, OH
    48hr bump
  19. #19 Re: 3k converter, Pushrods, Front cover, L26 UIM, ARP Main Studs, Trans Parts, HV2..
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Hmmmmm......pm'd
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  20. #20 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Lorain, OH
    buuump
  1. Doing LIM and Valve Cover Gaskets
    By djimmy31 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2009, 07:08 PM
  2. Valve Cover Gaskets
    By fragrep in forum General Tech Discussion
    Last Post: 03-11-2009, 07:46 PM
