Thread: Pontiac Grand Prix HID Conversion Kit! Plug & Play Installation!
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 137
  1. #1 Pontiac Grand Prix HID Conversion Kit! Plug & Play Installation!
    Donating Users Paul J McCain's Avatar
    St. Louis, MO
    Pontiac Grand Prix HID Conversion Kits
    This kit has been carefully designed from the ground up to be the highest-quality HID kit available on the market, without exception.
    Ballast: The ballasts are the most important component of an HID kit, as they provide the power. After years of providing midrange and high-quality ballasts for vehicles of all makes and models, Diode Dynamics learned what was important in making a good ballast, and applied it when designing these.
    Controller Chip. Most digital (DSP) ballasts on the market still use generic chips, which are cheap, and work pretty well. However, when you need maximum quality, you need a new computer chip designed for one purpose. This is known as an Application-Specific Integrated Circuit (ASIC). These ballasts use brand new DSP ASIC chips for maximum efficiency and brightness, fast warmup time, and extremely stable operation.
    CAN-BUS. Some vehicles have systems which sense the power consumption. Since HIDs use less power than factory halogen bulbs, this can cause issues. You can resolve this by adding capacitors, known as warning cancellers, or some ballasts come with them built-in. However, sometimes that's still not enough to trick the vehicle! To fix it, this ballast has not one, but two CAN-BUS modules, which provide capacitance and resistance to the circuit to defeat even the most troublesome modern CANBUS systems. Even if your vehicle does not use a CAN-BUS system, these modules will provide extra power smoothing for reliable operation. Simply put, this ballast will work on any vehicle, the first time you plug it in. With this kit, you don't need to worry about capacitors, warning cancellers, or resistors.
    Igniter and Startup. You may have heard of ignition issues with other ballasts, caused by an igniter that is too small to withstand cold temperatures. No reason to worry with these ballasts- the oversized 24kV external igniter means that you will never have an ignition issue, even in the coldest temperatures. Additionally, the ASIC chip in these ballasts means that you only need 4 amps at nominal voltage to start up. These ballasts consume less power than any other on the market, meaning 100% reliable and fast startups, every time.
    Shielding. Ever noticed a little black plastic thing clipped onto your laptop charger cord? That's a ferrite bead, which is used to suppress high-frequency signals, which can create radio interference. All ballasts generate these signals, and most just have protection in the ballast. We've also included ferrite beads on the wire, to suppress them.
    LED Indicator. Convenience is key, especially during installation. To make things easy, we've added an indicator LED on the input wire, so you know that the ballast is getting power.
    Case. These ballasts are the smallest you will find, about the size of a pack of playing cards. The case is fully potted, or filled with epoxy, which makes them fully waterproof and shockproof. Most ballasts on the market are filled to some degree, but these are completely filled to the top, sparing no expense to ensure longevity.
    Bulbs:
    The bulbs included with Diode Dynamics kits are CNLight bulbs. CNLight is the top manufacturer of aftermarket bulbs in the world, providing the best quality available. You might see other high-quality kits on the market which also use CNLight bulbs. They provide superior life, brightness, and color attenuation when compared to generic HID bulbs, like those found in most cheaper kits on the market. The one-piece base design prevents any issues with separation over time, making the entire bulb extremely reliable.
    The CNLight bulb temperatures are rated accurately in Kelvin temperature at 35W, and have an industry-standard 3000 hours of estimated bulb life, which should outlast your vehicle. Please be aware that most HID bulbs are rated inaccurately from other manufacturers. 8000K is not dark blue, and 6000K is not pure white! We provide accurately-measured colors. 3000K is our lowest temperature, and has a pure yellow output, which is great for use in fog lights. 4300K is a pure white output, as seen on many factory HIDs. It will not have any blue tint to its color, and might appear slightly warm. 6000K is our most popular color, which produces an ice white color. It has a very slight hint of blue, and matches best with most LEDs. 8000K is our highest temperature, which produces an ice blue color. This is not a strong blue color though- it is still primarily white, meaning there will be no decrease in light output.
    Relay:
    Your Premium CAN-BUS HID Kit includes a brand new Heavy-Duty HID Relay, to power your HIDs directly from the battery, instead of the factory wiring. This relay has been designed from scratch, and utilizes a fully-sealed, waterproof relay, with flyback diode, and even has a built-in capacitor for input power smoothing. All wires are sleeved with braided techflex for an attractive appearance and extra protection. The input wires are each a meter long, and the output wires are one meter and two meters, which means the wiring will be long enough for even the biggest vehicles. The single-ground design makes installation easy. This relay was designed with reliability, convenience, and long-life in mind.
    Warranty: Our warranty is through Diode Dynamics, LLC, so you can be assured that you will get fast and friendly service should you have any problems. There is a full-replacement 1-year warranty on all HID Kit components, including HID Bulbs, Ballasts and Relay.
    Shipment: We carry our own inventory, so no waiting for them to be shipped from overseas, or waiting on big, unreliable suppliers to ship them. They ship right from our own inventory, in St. Louis, Missouri, usually the same day you order.
    Kit comes with:
    • One pair HID bulbs in your choice of bulb size and color
    • Two 35w super-slim ballasts
    • Mounting hardware for ballasts
    • Three-year limited warranty on all components
    • Free Diode Dynamics decal
    • Diode Dynamics 30-day satisfaction guarantee
    • Heavy-duty HID Relay Harness (Optional) to protect your factory electronics.
    High Beam HID Conversion Kit for 2004-2008 Pontiac Grand Prix
    Low Beam HID Conversion Kit for 2004-2008 Pontiac Grand Prix
    Fog Light HID Conversion Kit for 2004-2008 Pontiac Grand Prix
    1997-2003 Pontiac Grand Prix HI/LO Kit
    If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com
    *PM us for the free-shipping code* (U.S. forum members only)
    Thanks for looking!
    Nick C.
    Click For All Pontiac Lighting
    Your Experts in Pontiac Lighting
    (314) 205-3033
  2. #2 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    GT Level Member gpgt04's Avatar
    MA
    any of these kits comparable to the 898 bulb?
  3. #3 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    St. Louis, MO
    Hello!
    898 is the same bulb size as 881/880.
    Thanks!
    Paul
    (314) 205-3033
  4. #4 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    GT Level Member supercharged06's Avatar
    capecod
    Gota bulb number for 06 grand prix GT supercharged?
    6000-white
    OR next up which is a light blue
    let me know Thanks
  5. #5 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    St. Louis, MO
    Hello,
    You need a 9006 size kit.
    Thanks!
    Paul
    (314) 205-3033
  6. #6 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    capecod
    do you have them? high and low beam?
  7. #7 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    St. Louis, MO
    Yep! Plenty in stock. It'd just be for low beam.
    (314) 205-3033
  8. #8 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    GT Level Member sic6's Avatar
    san marcos, tx
    Do you sell replacement bulbs? Looking to get either the 5k or 6k.
  9. #9 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    St. Louis, MO
    Yes, PM replied
    (314) 205-3033
  10. #10 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    St. Cloud, MN
    Paul,
    Just curious if you will be having these on sale again for black friday this year?
    Thanks!
  11. #11 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    anything for a 1995 gp with the sealed beams?
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  12. #12 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    St. Louis, MO
    Yes, watch for black friday sale announcements soon! Our only sale of the year.
    We currently don't have any sealed-beam items available.
    (314) 205-3033
  13. #13 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    Ohio
    Plug N Play for an 06 GP? I've heard modification needs to be done on 06+ cars... true?
  14. #14 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    St. Cloud, MN
    No modification needed for HID kits, just plug and play for your 06.
  15. #15 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    St. Louis, MO
    Thanks for the answer!
    (314) 205-3033
  16. #16 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    Newark, Delaware
    my 01 has is 9007 and the high and low bwam uses the same bulb. what does the hid low halogen high mean on your order page?
  17. #17 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    St. Louis, MO
    The bulb has a HID low beam on it, and a small halogen bulb for the high beam. It works very reliably. We tried a lot of dual HID kits but the motorized functions all fail pretty quickly.
    (314) 205-3033
  18. #18 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    Jul 2011
    NW Ohio, USA
    Quote Originally Posted by Paul J McCain View Post
    Please feel free to post questions, comments, and concerns!
    I don't have any comments, but I'm sure full of questions and concerns!
    Paul, not sure if you're the guy to ask this, but my question is I've been looking at a nice set of glass housings for a possible HID fog light install in my 1998 GT, but the kit says the bulb type required is a "H3" instead of the usual "880" like I have now. I'm wondering that, if I get these glass housings, is there a way I could use your Grand Prix HID Fog Light Conversion Kit in the glass housings specified for a "H3" bulb?
    Thanks!
    I Gotz Moar Powar Than U Gotz
    The HWG Thread = Winning.
  19. #19 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    should be able to you have to tell them what kinda bulbs you want anyway
    SMGPFC Member #10
  20. #20 Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
    Jul 2011
    NW Ohio, USA
    That's a negative Ghost Rider.
    I checked Diode Dynamics - Pontiac Grand Prix Fog Light HID Conversion Kit (that's a link to the page for their GP HID fog light conversion kit) and in the dropdown box it only has 880 listed.
    Unless I could somehow get ahold of somebody at Diode Dynamics and see if I could get different bulbs shipped with the kit. I'd really like a set of HC3's (what I understand to be the smaller equivilant to H3's while fitting in the same socket), but it looks like I might have to think of some other way to do this....
  1. Website to check out, including the MustRanger...this is bad..
    By Pittman06 in forum Off Topic Discussion
    Last Post: 12-12-2009, 11:03 PM
  2. questions on HID conversion kits
    By duffman87 in forum General Tech Discussion
    Last Post: 06-22-2009, 09:35 PM
  3. Some updated photos including true fire engine bay
    By VictorSmalls in forum Visual/Body Modifications
    Last Post: 04-30-2009, 07:13 AM
  4. HID Conversion Kits
    By DJFirestorm07 in forum Visual/Body Modifications
    Last Post: 11-25-2008, 12:40 PM
  5. E85 Conversion Kits
    By Quicklynx in forum General Tech Discussion
    Last Post: 09-05-2008, 03:29 PM
