Thread: engine bay cleaning
Results 1 to 3 of 3
  1. #1 engine bay cleaning
    May 2011
    winnipeg
    Can anybody tell me if simple green is a good engine bay cleaner and what do you apply after the engine bay is clean to give it that new
    car look? What precautions do I need to take for electronic connections and components when washing and is it a good idea to use a
    pressure washer?
    Dec 2010
    DMV
    Cover the coil packs, alternator, air filter. Apply simple green heavily, let it soak then spray with pressure washer.
    I've done this a few times and it works for me.
    Afterwards spray some tire shine on the engine bay to give it "new" look.
  3. #3 Re: engine bay cleaning
    i just used crc engine de greaser ( i usually use foamy engine brite) but the crc was on sale, and it cleaned up my old oil leaks nice, and left no stink after i hosed it down.
    i cover NOTHING, except for my open cone filter, if you still have the stock air box, you really dont need to worry about anything getting wet. just dont full blast the alt or coils. all the wires have weather pac connections so they are all safe to get wet.
    id stay away from a high pressure washer too, you can rip your wires out with it or break vac lines.
    garden hose with a spray nozzle at full blast is more than enough.
    i like to get the car on ramps, and spray the bottom first, and then the top, hose the bottom first, then the top, as all that crap will be dripping on you.
    if you have a air compressor, with a blow nozzle for it, its nice to dry it up with that. well the lim valleys and what not where water can puddle up.
    and i did the tire shine engine detail, and it collects dirt and dust and your in worse shape a month later that you were before you used tire shine. looks good for a month tho.
    wear some old cloths, and try to have some goggles to protect your eyes when spraying this stuff, and hosing it off. it will burn your eyes.
  1. Cleaning Engine Bay
    By SupaCharg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2012, 03:20 PM
  2. engine cleaning
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:53 PM
  3. cleaning engine??
    By kjohnson in forum Visual/Body Modifications
    Last Post: 11-19-2009, 07:39 AM
  4. Cleaning up the engine bay
    By Clar2478 in forum Visual/Body Modifications
    Last Post: 03-23-2009, 01:44 AM
  5. Engine Cleaning
    By wrfdff4 in forum Visual/Body Modifications
    Last Post: 03-19-2008, 09:04 PM
