Thread: How To Detail Engine Bay
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 How To Detail Engine Bay
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    This write-up is kind of from another forum but I used a different method when detailing the engine bay.
    Supplies: Awesome
    Garbage Bags
    Paint Brush(s)
    Micro Fiber Cloths
    Paper Towels if you don't have Micro Fiber Cloths
    Garden Hose with water
    Time
    Before you start the entire process if you do not have a cleaner/degreaser you can run to your local Dollar Store to pick up some Awesome which works FANTASTIC.
    To start off with you will need to tape/bag off things in your engine bay that does not take kindly to water, for example the battery, alternator, air filter (if running open cone), PCM and all the other good stuff.
    Next you will want to get your degreaser (Awesome) and spray it onto the part/area you want to clean.
    After you spray the cleaner on their you will want to use a paint brush (doesn't matter on size) to agitate the soil/dirt on the surface.
    Once agitated you will take the garden hose and lightly spray it onto what you have agitated.
    After you spray it off with the garden hose you can wipe it off with a microfiber cloth.
    Repeat the above steps until it is totally clean.
    Enjoy a nice clean engine bay.
    Here are some before and after pictures
    And here you can tell the difference between where it was cleaned and agitated versus nothing.
  2. #2 Re: How To Detail Engine Bay
    damn that stuff works well!
    never heard of awesome.
  3. #3 Re: How To Detail Engine Bay
    For a finishing touch...granted I can't see the pictures at work...but spray everything plastic/black with tire FOAM and let it sit for a few minutes then wipe clean.
    Seriously...awesome...results.
  4. #4 Re: How To Detail Engine Bay
    Florida
    Orrr Get some Turtle Wax CD2...And spray the living **** out of everything, take it for a spin, and let it bake onto everything, then wipe off any excess...The whole entire bay will be sparkley awesome.
  5. #5 Re: How To Detail Engine Bay
    Pennsylvania
    More Power: Turtle Wax CD2 Engine Cleaner and Detailer
  6. #6 Re: How To Detail Engine Bay
    that is the cleanest engine bay ive ever seen and the car is super clean by itself but that is just crazy clean
    SMGPFC Member #10
  7. #7 Re: How To Detail Engine Bay
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Neat little writeup! Good job!
    For all your 3800 needs:
  8. #8 Re: How To Detail Engine Bay
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    that dollar store stuff did that? WOW thats amazing. im gunna have to try this good job bud
  9. #9 Re: How To Detail Engine Bay
    Nov 2009
    Thanks for the comment guys. And yes Boostn it was dollar store stuff so if you have a used paint brush all you have to spend money on is Awesome. And it is only a buck so you can detail your engine bay with only a dollar and like ten cents.
  10. #10 Re: How To Detail Engine Bay
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    what all cant be touched by water?
    Buffalo
    Try to avoid the coil pac/icm area and the alternator. But again it's a motor, designed to go tru rain/snow/dirt, in other words, it's ok to get wet.
  12. #12 Re: How To Detail Engine Bay
    Nov 2009
    Like mentioned above the alternator, avoid water (shorting it), coil pacs. That is what the garbage bags are for though (keep water off the stuff that doesn't like water).
  13. #13 Re: How To Detail Engine Bay
    Nov 2011
    Decatur
    should you cover the fuse box?
  14. #14 Re: How To Detail Engine Bay
    Nov 2009
    It would be up to you really. To be on the safe side you can. On the other hand you can just watch the amount of water you pour in that area.
  15. #15 Re: How To Detail Engine Bay
    Nov 2011
    Decatur
    alright thanks for the help!
  16. #16 Re: How To Detail Engine Bay
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    This stuff works great! Here's mine that I just did!
    (I only covered the air filter, but I don't plan on driving my car any more today, so all the electronics will have all day to dry out.
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  17. #17 Re: How To Detail Engine Bay
    Nov 2009
    ^ clean
  18. #18 Re: How To Detail Engine Bay
    Tyler, TX
    Thanks!
    more pics can be found here: http://www.grandprixforums.net/detai...day-56449.html
  19. #19 Re: How To Detail Engine Bay
    Nov 2011
    Decatur
    what about using tuff stuff for the hood liner?
  20. #20 Re: How To Detail Engine Bay
    Nov 2009
    For the hood liner I just took a nylon brush that I got in a set with brass and steel. Used some car soap and just scrubbed it. Left it out in the sun to try out over a day or so.
  1. Some new mods + a major detail, claybarred etc.
    By boostedzx3 in forum Visual/Body Modifications
    Last Post: 05-27-2010, 09:28 PM
  2. Engine Detail/Paint
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 09-14-2008, 11:00 AM
  3. Engine bay detail parts questions...
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 07-12-2008, 11:26 PM
  4. fresh detail pics
    By UR LOSN in forum Visual/Body Modifications
    Last Post: 05-22-2008, 11:27 AM
  5. Suggestion: Detail thread?
    By GP2003GT in forum Forum Bugs/Suggestions
    Last Post: 03-13-2008, 07:57 PM
