Thread: How to remove "sticky weight" residue from wheels?
Results 1 to 13 of 13
  1. #1 How to remove "sticky weight" residue from wheels?
    Sep 2014
    Worcester, MA
    Does anyone have a good way to remove the residue from "sticky weights" from wheels? (If there is an acid of some kind, hopefully one that doesn't damage the finish on the wheels)
    I've tried brake cleaner, adhesive remover, etc., all with less success than I'd like. I know there are stronger acids available but I don't want to damage the wheel finish.
    (The wheel would be off the car to do this)
    Thanks
    -Bob C.
  2. #2 Re: How to remove "sticky weight" residue from wheels?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Is this on the inside of the wheel? If so, use a wire wheel. If on the outside, try Goo Gone.
  3. #3 Re: How to remove "sticky weight" residue from wheels?
    I always use brake cleaner with a rag and just rub the **** out of it.
    I've balanced enough rims in the past to know how stupid some brands are to get off.
    A wire wheel will damaged the rims, it will remove clear coat and paint. Only use that if the rim is already half junk and peeling.
  4. #4 Re: How to remove "sticky weight" residue from wheels?
    Apr 2015
    The inside of the rim isn't clear coated like the outside, is it?
  5. #5 Re: How to remove "sticky weight" residue from wheels?
    Sep 2014
    Worcester, MA
    Quote Originally Posted by SubwayBrat View Post
    Sure is. Obviously the inside of the wheel is less visible, but if you grind through the clear coat then that area would be more susceptible to picking up brake dust in the future.
    Have you actually used goo-gone for this?
  6. #6 Re: How to remove "sticky weight" residue from wheels?
    Apr 2015
    Quote Originally Posted by bobc455 View Post
    No, but Goo Gone is famous for getting rid of sticker residue and it doesn't harm paint or clear coat. My brother has used it on his door before.
  7. #7 Re: How to remove "sticky weight" residue from wheels?
    Jan 2014
    AR
    This or wax and grease remover and rub a lot. Use a softer plastic or wood tool to scrape the excess off while wet, without scratching. Then go from wet rag to dry rag alternatively (Cotton. Or terry or microfiber for more scrubbiness) with the solvent for quickest results. It won't harm the finish but you'll probably want to rub it with some polish afterwards. Care for the shiny face of the wheel as you would paint. Just my 2 cents!
  8. #8 Re: How to remove "sticky weight" residue from wheels?
    Sep 2014
    Worcester, MA
    IDJ, is that available retail anywhere? A quick look seems that it is available through industrial sales channels only.
  9. #9 Re: How to remove "sticky weight" residue from wheels?
    Jan 2014
    AR
    An auto parts store that sells paint and body shop stuff should have that or be able to get it. Can they sell it to an individual? I don't know about in MA. If you can't locate some, WD-40 will also soften it without harm to the wheel. Leaves it oily though. Any paint prep wax and grease remover would do the same job. The 3M adhesive remover is about the mildest solvent there is. Once there's a can of it on your shelf, you may be amazed at how many uses you'll find for the stuff.
  10. #10 Re: How to remove "sticky weight" residue from wheels?
    Jan 2014
    AR
    By the way, its also available in smaller sized aerosol. The quart size is a lot if you are just removing wheel weight goo. But its great for road tar, tree sap, grease on carpet, etc. Lots of uses in and around the home as well.
  11. #11 Re: How to remove "sticky weight" residue from wheels?
    Jan 2014
    AR
    Just re-read your first entry. If solvents fail, the next move is polish. Those also contain mild solvent but have the added scrubbing action since they aren't just clear liquid. Just avoid rubbing compound that feels gritty and kills gloss. Try any auto paint polish you've got. Either way, elbow grease is what really does the work! Mention of acids is scary to me, I would not try any because I'm simply not familiar with them.
  12. #12 Re: How to remove "sticky weight" residue from wheels?
    Sep 2014
    Worcester, MA
    That's different than what I've tried before, so I'm going to give it a shot. I called a local Advance Auto, who managed to find some available from their distributors so I'll get it next week.
    I remember seeing that stuff in a past life at a machinery company, where it was used on the assembly floor, and it seemed like the guys were always using it.
    Thanks!
  13. #13 Re: How to remove "sticky weight" residue from wheels?
    Nov 2012
    Madison
    Use a hairdryer and get it warm. I would say use a heat gun but a hair dryer is safer.
  1. How to remove "Upper Trim Panel" on the dash?
    By Metal Links in forum Visual/Body Modifications
    Last Post: 09-09-2016, 11:04 PM
  2. Weight Loss or Weight Gain Thread "2012"
    By benner in forum Off Topic Discussion
    Last Post: 08-24-2014, 12:27 AM
  3. "6 sec full weight regal" lmao
    By gojo83 in forum Off Topic Discussion
    Last Post: 07-08-2013, 10:25 AM
  4. Can't remove plastic "nut" holding spare tire in well.
    By clagrow in forum General Tech Discussion
    Last Post: 01-06-2013, 01:08 AM
  5. how to remove "Service Tire Monitor System"
    By 04GT in forum 04+ Specifics
    Last Post: 12-20-2011, 10:13 AM
