Thread: Lowering Spring Vibration Motor Mount Spacers
Page 1 of 9 123 ... LastLast
Results 1 to 20 of 176
  1. #1 Lowering Spring Vibration Motor Mount Spacers
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    READY TO SHIP!!!!
    If you have:
    3" DP
    97-03 or 04+ Special Edition hood
    2.25" intercooler and fuel lines going over the top still and will not change them
    You may only be able to fit a half set, BUT I haven't had a report of only a half set fitting in about 5 years so I still recommend ordering the full set.
    Pictures of the prototype set and current version can be seen here:
    VinnieMD/Spacers - Photobucket - Video and Image Hosting
    Main Thread With Pics and Install Instructions:
    ClubGP Message Forum troubleshooting
    Install Instructions - READ ME PLEASE:
    3800Pro Install Instructions
    Paypal info,
    $53 to vinniemd1@aim.com
    Lets get rid of vibrations the right way now!
    Vinnie DiRenzo
  2. #2 Re: Motor Mount Spacers are back!
    i dont have money to spare yet, but i may end up sending it to you after i get paid.
  3. #3 Re: Motor Mount Spacers are back!
    Las Cruces, NM
    Cool.
    Just be sure to put which forum you are from and your username in the paypal comments.
    If you are from the "other", forum PM me on there since it's where I keep all my info stored as to who has bought and who is interested.
  4. #4 Re: Motor Mount Spacers are back!
    Wichita, KS
    Only sucks that the studs from the motor mounts are so short. I wonder if you could incorporate a thread on stud extender, which would also increase the O.D. of the stud and you could run a larger nut. That would be a good side effect to benefit you even more.
    Idea to consider for a revised set in the future.
    ~F~
  5. #5 Re: Motor Mount Spacers are back!
    Las Cruces, NM
    That is a good suggestion. I'll start looking into that one.
    Thanks for the feedback.
    Vinnie
  6. #6 Re: Motor Mount Spacers are back!
    Wichita, KS
    I was thinking about this today, and persionally how I would add for the longer threaded part, would be to add a threaded stud on the end of it. It would screw onto the stock motor mount studs, and then have a bolt hole on the other end, then instead of using a nut to attach the mount to the bracket, you would use a high quality bolt.
    Think of it like a "peg" we used to all run back in the day on our BMX bikes so we could haul our friends around on the back. But smaller of course.
    ~F~
  7. #7 Re: Motor Mount Spacers are back!
    Las Cruces, NM
    TTT
    4 sold
  8. #8 Re: Motor Mount Spacers are back!
    Las Cruces, NM
    They are in stock NOW!
  9. #9 Re: Motor Mount Spacers are back!
    GT Level Member TurboKent's Avatar
    Woodward, OK
    money sent.
  10. #10 Re: Motor Mount Spacers are back!
    Las Cruces, NM
    I got it. They will ship tomorrow!
  11. #11 Re: Motor Mount Spacers are back!
    SE Level Member Zach3800's Avatar
    Waterloo IL
    do you still have some PM because I'll forget to check here
    All you need to know is High compression big a$$ Cam plus blower
  12. #12 Re: Motor Mount Spacers are back!
    Ohio
    I am planning on lowering 1.7 with the intrax springs. Would these be a good idea even though im going lower than 1.5 which you stated in the clubgp post was the apprx these are good for. Or should i be looking at shortened dogbones and poly mounts?
    00 GTP demodded and forsale
  13. #13 Re: Motor Mount Spacers are back!
    Las Cruces, NM
    No, these will still work better then those 2. It's not that the dopbbones work better at lower drops, its that NONE of the solutions can handly drops of 2+ inches from bagging the car.
    But mine are our of stock for a few months. I'll change this post to reflect all updates.
  14. #14 Re: Motor Mount Spacers are back!
    Ohio
    Alright sounds good. Send me a pm ar email me at sbrady6@emich.edu when you some back in stock and i will take a set off your hands.
  15. #15 Re: Motor Mount Spacers are back!
    Greensburg, PA
    How do these compair to ZZP's engine and Tran's spacers? Pretty much the same thing?
    Mods:3.4 pulley + recommended mods/ F-Body Front & rear GXP Calipers/ GMPP handling upgrade kit + otto strut brace/ SSC Gen 1 Springs on GR-2 struts/ Verde 5 18x8 Rims
  16. #16 Re: Motor Mount Spacers are back!
    Las Cruces, NM
    I spoke with my buddy at the shop today. He's getting a quote for me ASAP.
    ZZPs are dangerous. They are too thick for the studs on the stock mounts. Mine are thinner but go on top and bottom so they give you a greater lift.
  17. #17 Re: Motor Mount Spacers are back!
    Jan 1970
    Maquoketa, Iowa
    I have SSC springs, MPD F1 hood, 2.25" IC with ZZP fuel logs and Pacesetter headers... Will I have to cut into my MPD hood after installing these or worry about my pacesetters hitting the firewall? Might be a trial and error thing anyway...
  18. #18 Re: Motor Mount Spacers are back!
    Las Cruces, NM
    The best way it to put a piece of 3/4" plywood about the size of the blower on top of the engine and see if the hood closes.
  19. #19 Re: Motor Mount Spacers are back!
    Oct 2008
    michigan
    I have a 04 GT and I have a set of eibach springs...what spacers combo would you suggest me?
  20. #20 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    NEW STOCK IS IN. See first post.
  1. Engine mount idea
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 06-04-2008, 09:56 AM
  2. How bad is it to run 12" rotors, Front & Back?
    By Incomudrox in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2008, 06:59 PM
  3. MPH in the back half
    By Ron Vogel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2008, 01:35 AM
  4. Rust behind and under back seat
    By 03GPScottyd in forum Visual/Body Modifications
    Last Post: 01-04-2008, 03:36 PM
