Thread: Lowering Spring Vibration Motor Mount Spacers
Page 2 of 9 FirstFirst 1234 ... LastLast
Results 21 to 40 of 176
  1. #21 Re: Motor Mount Spacers are back! AND ALUMINUM!
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    39 left
  2. #22 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
  3. #23 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
  4. #24 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    33 left. Sold 2 sets to Tim King.
  5. #25 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Ohio
    Vinnie I finally am gettin suspension parts ordered an am gonna need some. I have a 3in dp though so i need a half set. Do you still have some?
    00 GTP demodded and forsale
  6. #26 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    I have plenty left. Only a few had had complaints with the 3" DP so I list it more as a warning. You can always sell the other half set if you cant use the full 3/4". Its designed that way so you arent screwed if you think you have the room and really dont.
  7. #27 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Ohio
    Sounds good i want a set. what happens w/ the 3inch that was complained about? does it hit the swaybar?
  8. #28 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    It actually hit the firewall in those cases. Just use the PayPal info from the first post and they'll go out tomorrow.
    Vinnie
  9. #29 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Ohio
    Alright sounds good im gonna go w a half set to avoid any possible hitting
  10. #30 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Ohio
    payment sent
  11. #31 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    Got it, they'll ship out tomorrow!
  12. #32 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Ohio
    Awesome, thanks Vinnie
  13. #33 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Donating User Odi's Avatar
    Chicago South Suburbs
    Are these still for sale? Asking ahead to know if I should get shorter Dogbones or the real deal when purchasing springs
  14. #34 Re: Motor Mount Spacers are back! AND ALUMINUM!
  15. #35 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    Quote Originally Posted by MiriV View Post
    Yes sir!!! Still have them and they are ready to go in the mail when you need them.
    Vinnie
  16. #36 Re: Motor Mount Spacers are back! AND ALUMINUM!
    thanks vinnie, ill get to you when i get springs, which should be in a matter of 3-4 weeks.
  17. #37 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    Sounds good!
  18. #38 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    Still available!!!
  19. #39 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    Now through Memorial Day, I'll be taking the shipping charge off.
    Get um while they're hot!!!
  20. #40 Re: Motor Mount Spacers are back! AND ALUMINUM!
    Las Cruces, NM
    I have some left. Getm the before I go on vacation next week and have to add the shipping charge back on.
  1. Engine mount idea
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 06-04-2008, 09:56 AM
  2. How bad is it to run 12" rotors, Front & Back?
    By Incomudrox in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2008, 06:59 PM
  3. MPH in the back half
    By Ron Vogel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2008, 01:35 AM
  4. Rust behind and under back seat
    By 03GPScottyd in forum Visual/Body Modifications
    Last Post: 01-04-2008, 03:36 PM
