Thread: monte
Results 1 to 10 of 10
  1. #1 monte
    SE Level Member roxettelook's Avatar
    bucksport maine
    i have the gray ground effects on the bottom of my car and it is starting to peel in small spots any one no how to fix this problem or ideas to make it look newer seems the crap they use to make this cars is not long lasting laurie
  2. #2 Re: monte
    GT Level Member 7801MonteMan's Avatar
    S.E Michigan
    Without seeing exactly what your talking about and how big the spots are you may beable to touch up. Otherwise if the spots are to big to be touched up you may be forced to live with it or repainted.
    ASE Certified and I-Car Auto Refinishing Paint Technician
    -78 Monte Carlo -01 Monte Carlo LSX
  3. #3 Re: monte
    bucksport maine
    thanks for replyin well it looks like the flim is comming off so it has like spots of tears from material im not sure i will have to take a close up pic and send it to ya im not sure if its paint or what that material is made off do you no this anwer thanks laurie
  4. #4 Re: monte
    chicago
    x2 like monteman said^^^
  5. #5 Re: monte
    bucksport maine
    ok ill get pics that way u can see what im askin about
  6. #6 Re: monte
    Lenexa, KS
    X3 on monteman. My old camaro was doing that, fortunately it is easier to get trim for an 89 camaro so I bought from a bone yard. $25 over several hundred
  7. #7 Re: monte
    SE Level Member fever42's Avatar
    May 2008
    Mobile, Al
    Are you talking about the highsport package, mind was painted on, its paint code is FM8132 and clear, plastic-kota touchup brand, this was the only one i could find to match without going to a body shop., Since then have went all black
  8. #8 Re: monte
    SE Level Member bct717's Avatar
    Indiana
    Does anyone know where you can buy that gray factory ground effect?
  9. #9 Re: monte
    SE Level Member 04intimidatorSS's Avatar
    Saint Louis
    not sure :/ sorry
    MODS: u bend delete, resonator delete, 3 inch ZZP bolt in catted DP, PLOG, 180* stat, Dogbone flip, CAI, AL 104's gaped at .052, ported blower, 3.5 and (3.4 current pulley) PCM tune by STL98GTP
  10. #10 Re: monte
    chicago
    www.gmpartsdirect.com
    i have the front and rear pieces and they are silver. the front have little tear but body shop should be able to fix it.
  1. any monte carlo?
    By nemesis in forum Chevrolet Monte Carlo
    Last Post: 01-09-2015, 01:43 AM
  2. hey monte carlo ss owner new at this
    By roxettelook in forum Introductions/Noob Questions
    Last Post: 02-03-2008, 09:19 AM
  3. thinking about switching to 06 monte ss seats
    By s1795so2 in forum Visual/Body Modifications
    Last Post: 01-06-2008, 01:29 AM
