Thread: Are police packaged impalas good?
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41 Re: Are police packaged impalas good?
    Aug 2012
    charleston sc
    Had a 01 Galaxy silver 9C1, had the serve switch unistalled though they put it in the glove box??? I remember a tranny an engine cooler being in there also. . . l36 3.8lt
  2. #42 Re: Are police packaged impalas good?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    better gear ratio, stiffer suspension, has gmpp sway bars etc. sits 1'' higher then a impala ls.
    alot heavier.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  3. #43 Re: Are police packaged impalas good?
    Why is it a lot heavier?
  4. #44 Re: Are police packaged impalas good?
    St Thomas Ontario
    got a good 100+ pounds in wiring they leave inside the car for all the lights, brother worked at the police college when they got rid of the cars the just cut everything off and sell. its not alot heavier but every 100 pounds matters, specially for our 16 second cars lols.
  5. #45 Re: Are police packaged impalas good?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    I have recently became the owner of a '04 Impala 9C1. That being said I have been kinda forced into researching this topic first hand after my transmission took a **** and caught on fire (long story). This thread does have a lot information that I found useful, so I'll source some more. I had previously believed that the 9C1's had the HD transmission, but sadly they don't according to the information I found on this site here
    https://m.facebook.com/GM3800Tips/posts/577991379016695
    ^^^It is probably the best source of transmission compatibility information for our platforms I've ever come across.
  6. #46 Re: Are police packaged impalas good?
    do you have the data base loaded up and set up in dhp? if your all set up you can always load up a non po po package bin some bins are not mapped but the pcm will take another bin for your year car.
  7. #47 Re: Are police packaged impalas good?
    have you used the dhp on any other cars is what im asking,?
    theres a data base you need to drop in the dhp folder, then select database. its part of the set up when you first install it.
    and yes your pcm will take another bin file. heres a load of 04 imppy bins https://www.dropbox.com/sh/4v89affyj...uYcEnZDCa?dl=0
  8. #48 Re: Are police packaged impalas good?
    Jul 2008
    Dekalb, IL
    What exactly do you mean by having the DHP database loaded up and set up? I have found a bunch of BIN files online but I don't think I have a BIN file for a '04 Impala. Pretty sure I have some for the previous years though. My concern is that if I'm able to flash another BIN file on from another Impala, will it still communicate correctly with the BCM on my 9C1 or will I have just screwed myself since I do not have a copy of the original bin file? The fact that access to the original BIN file on my PCM seems locked out to my tuner worries me.
  9. #49 Re: Are police packaged impalas good?
    bcm and pcm are two different things, one has nothing to do with the other. your are working on the PCM only.
    and i explained the database in my last post. its what makes dhp work. its a list of mapped bins for dhp, its part of the operating system i guess you could say.
  10. #50 Re: Are police packaged impalas good?
    Jul 2008
    Dekalb, IL
    Yes I've used my DHP on several GTP's in the past. It's been close to 8 years since I set it up so I don't really remember setting up the database. Thanks for the link to those '04 BIN's, you have just given me some more hope for this car. Because if this works then hopefully I can put whatever is salvageable from my previous built, cammed, GenV setup to good use!
  11. #51 Re: Are police packaged impalas good?
    Jul 2008
    Dekalb, IL
    Hmm for some reason PowrTuner won't open up that '04 Impala L36 - Police Stock BIN file. It opens up the rest of the BIN's just fine except for one other. Hopefully I can just use one of the non police model BIN files and just change the VIN to mine and get it to work without having to reprogram the 9C1 BCM.
  12. #52 Re: Are police packaged impalas good?
    your pcm will retain its vin #, just check it after you flash it. some bins are corrupt it seems. i just dl'ed that one and checked the one on my hard drive, neither will open.
    other then maybe a gear change in the bin a normal file should work i think.
  13. #53 Re: Are police packaged impalas good?
    Jul 2008
    Dekalb, IL
    I'll give her a try. If it works I'm gonna be happy as hell to be back in the modding world.
  1. Anyone think this looks good??
    By hester21289 in forum Audio, Security & Visual Electronics
    Last Post: 09-22-2010, 12:52 AM
  2. How not to get away from the police lol
    By gtpinsc in forum Off Topic Discussion
    Last Post: 12-10-2008, 09:30 PM
  3. Good Buy ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-25-2008, 11:58 AM
  4. So this looks like a good little add on
    Last Post: 04-11-2008, 12:00 AM
  5. Good day!
    By bat119 in forum Introductions/Noob Questions
    Last Post: 03-06-2008, 07:36 PM
