Thread: Are police packaged impalas good?
Results 21 to 40 of 53
  1. #21 Re: Are police packaged impalas good?
    Odessa, MO
    Quote Originally Posted by Sabrewings View Post
    Also the fact that GM never made a 3.29 geared HD tranny and say so in their own SI manual.
    What is in the 04+ GTP's?
    Not trying to get in the middle here, but I do know they are stock with 3.29's. Are they not the 4T65EHD?
  2. #22 Re: Are police packaged impalas good?
    Barksdale AFB, LA
    Quote Originally Posted by Abrasive View Post
    I'd need to see the RPO code list on the back of them. According to GM's SI manual they didn't. But, with the RPO code off the SPID label I can look up their specific tranny code. If someone would care to provide me with one I will post up the info here.
    To be honest I've never looked at 04+ Grand Prix info.
    2009 Subaru Impreza WRX STI
  3. #23 Re: Are police packaged impalas good?
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    I'm pretty sure only the CompG GTP's have 3.29's, but those will have a different RPO code because of TAP Shift.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  4. #24 Re: Are police packaged impalas good?
    Barksdale AFB, LA
    I was recently given this info. (Thanks to BBEngineer)
    Quote Originally Posted by bbengineer
    It appears that the only car with a 4T65E-HD and an overall 3.29 FDR is the 2004+ GTP Comp-G with Tap-Shift (L32 Motor). The tranny RPO will be MN7, but the tranny model will be 4CBB (not 4CAB or 4CHB like most). Also the VIN will have engine code 4, not engine code 1
    The regulat 2004+ GTP has a 2.93 Overall FDR with an FR9 HD 3.29 FDR
    Another note:
    FR9 is 3.29 final drive ratio, but that is not overall final drive ratio. The overall final drive ratio uses the sprocket ratio as well.. that's why most HD's are 2.93 (33:37)
    Good resource from Llyod at Fast Fieros
    Transmission General Specificati
  5. #25 Re: Are police packaged impalas good?
    Dec 2008
    noblesville indiana
    i guess my question started a real dog fight. haha
  6. #26 Re: Are police packaged impalas good?
    Topeka, KS
    Quote Originally Posted by triplecanopy View Post
    Or Cat Fight
  7. #27 Re: Are police packaged impalas good?
    Central Wisconsin
    I am new to the site and I have a 2005 9C1 and it does have all the heavy duty cooling for the oil, trans., and steering. I will look into seeing what codes there are for the trans.
    Thanks
  8. #28 Re: Are police packaged impalas good?
    Banned - Busted For Scamming
    Feb 2009
    yea i know for a fact it has the oil cooler and additional trans cooler, i want to find another one and yank all the oil cooler stuff lol
  9. #29 Re: Are police packaged impalas good?
    Wausau, WI
    Quote Originally Posted by mr love77 View Post
    Thanks
    do you have the trans code yet?
  10. #30 Re: Are police packaged impalas good?
    Central Wisconsin
    Quote Originally Posted by Liquifire View Post
    I have the 2005 Impala 9C1 and upon checking the RPO codes, it has the M15 transmission. No MN7 trans. here!
    And it does for sure have all the coolers for trans., steering, and oil.
  11. #31 Re: Are police packaged impalas good?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    heres a question, i know when they sell police cars they have to "disable" certain things. one of those things is the switch used to disable the brake lights. i was wondering if anyone knew if they put the speed limiter back on when they go to sell them?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  12. #32 Re: Are police packaged impalas good?
    Barksdale AFB, LA
    Quote Originally Posted by Jakegday View Post
    Disabling the surv mode is easy, since all they do is either unplug the switch or cut the wires to the switch. The limiter is harder since that requires a reflash of the PCM. I'm not aware of how high the 9C1 goes, but I'd imagine it's the same after its police duty is over.
  13. #33 Re: Are police packaged impalas good?
    Charles City, IA
    My friend has one and it doesn't cut out according to him. Never was with him when he did it tho.
    SMGPFC Two Nipple General
  14. #34 Re: Are police packaged impalas good?
    GT Level Member flash527's Avatar
    Indianapolis, IN
    the COMP G's 04+ are 3.29. If it's not a COMP G but still a GTP (like mine) then its 2.93. I would know... I learned this the hard way.
    04 GTP - FOTB, Intense PCM, 180* Thermo, SLP Headers, 3.4" ZZP Modular Pulley, Moroso Race Wires, 104 Plugs, TEP trans: 3.29's, Thrasher shift kit. Soon to come: 13 inch dual piston brakes, rims and tires, wideband tune by PRJ.
  15. #35 Re: Are police packaged impalas good?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Impala cop car = FAIL
    Crown VIC (p71) = WIN
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  16. #36 Re: Are police packaged impalas good?
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    Quote Originally Posted by Street Wolf View Post
    Haha, uh no. If it's a police package Impala it has a HD transmission, the over sized radiator, transmission cooler, power steering cooler,a oil cooler, and slight computer work. Fans kick on sooner, and stay on longer.
    I bought a 9C1 and the trans is the same as the GP GT, only differ in it was alu-sub frame, P/S Cooler, Surv mode, stocks, and brakes and the PCM
    Everything got swapped into my 98 GP GT
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  17. #37 Re: Are police packaged impalas good?
  18. #38 Re: Are police packaged impalas good?
    May 2011
    Kansas City
    this is a super old thread.
    old thread is old? lol
    Reptile Tune (SOLD)
  19. #39 Re: Are police packaged impalas good?
    old meme is old.
  20. #40 Re: Are police packaged impalas good?
    Bunnell, FL
    well gonna use some info from here
    I'm a Sex Offender
  1. Anyone think this looks good??
    By hester21289 in forum Audio, Security & Visual Electronics
    Last Post: 09-22-2010, 12:52 AM
  2. How not to get away from the police lol
    By gtpinsc in forum Off Topic Discussion
    Last Post: 12-10-2008, 09:30 PM
  3. Good Buy ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-25-2008, 11:58 AM
  4. So this looks like a good little add on
    Last Post: 04-11-2008, 12:00 AM
  5. Good day!
    By bat119 in forum Introductions/Noob Questions
    Last Post: 03-06-2008, 07:36 PM
