2000 Imp. 3.4L. I'm trying to help a lady make her car safe. She's abused it and neglected it for past few years. She has an ambiguous and ever-changing story about a small front-end accident a few years ago--she got the body fixed, but nothing else, including broken front sway bar and broken right headlamp cover (bulbs are good). Anyway, according to her, ever since the accident; the horn stopped working, high beams work/flicker incrementally, and the corners don't blink--ie the corner (amber) turn signal lights come on but do not flash, and same for hazards-lights come on but do not flash. No issues with headlight low beam. I found a few wiring diagrams for it, but I do not know where grounds, etc. are located. I replaced horn fuse and horn is good again. So what's up with lights? Fault in circuit, right? Maybe bad head lamp assembly (ie the light sockets are built into housing)? Wiring diagram showed a "timer" for blinkers, but don't know how to test that. I put my voltmeter to blinkers and get a steady 11.8ish volts, but shouldn't the voltmeter read the current blinking? So, we greatly appreciate any help, where is turn sig "timer", where is ground for headlights? any experience with similar issues with these cars. Thanks!
