Thread: trans not shifting into OD
Results 1 to 5 of 5
  1. #1 trans not shifting into OD
    Dec 2014
    TN
    i have 2002 impala 3.8 had for a few years and i notice over time that the trans does not shift into OD if shift the other gears
    just fine but not sure OD does not i notice the rpms flutter here and their
  2. #2 Re: trans not shifting into OD
    Probably stripped the splines right off the 4th gear hub, pretty common issue on 97-02 transmissions with higher mileage.
  3. #3 Re: trans not shifting into OD
    Dec 2014
    TN
    yeah i has 170000 miles on it and so is their a way to fix this without another transmission
  4. #4 Re: trans not shifting into OD
    Mar 2014
    Tucson
    Just replace the stripped hub with the updated hardened unit.
    How to transmission 4th gear side cover access
  5. #5 Re: trans not shifting into OD
    Dec 2014
    TN
    Quote Originally Posted by BrandonHall10 View Post
    hey thanks im have to get some price quotes from some shops i dont have tools and nor space
  1. trans not shifting at all 4T65E-HD
    By pitifeo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2014, 09:10 AM
  2. Trans shifting problem
    By asite57 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-16-2011, 10:28 AM
  3. trans shifting too early
    By gpgtman83 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-06-2010, 02:55 PM
  4. Trans not shifting after warmed up
    By pos99se in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-04-2009, 11:29 PM
  5. Trans Shifting
    By GPSims39 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2008, 02:22 PM
