Thread: T-unit's boosted Buick AKA the Granny Slapper
Results 21 to 40 of 49
  1. #21 Re: T-unit's boosted Buick AKA the Granny Slapper
    GT Level Member sampuppy1's Avatar
    Mar 2016
    Yeah I have a feeling I'll be buying a set of 17s this spring. And snow tires for the following winter.
    Sent from a flagged XT1254
    Tyler/T-Unit
  2. #22 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Have a pile of parts stacking up. Oil pan is on my purchase list, solid lower engine mount too. Have a new oil pan gasket, valve cover gaskets, DIC and fog button setup to LED swap, oil change to do when the pan gets done, gentex rearview mirror to replace my garbage Donnelly stock unit, a trunk lid spoiler to paint and install, and a thorough spring cleaning.
    Man do I have my work cut out for me.
    Tyler/T-Unit
  3. #23 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Oh I knew I was forgetting something. I have a front window regulator to install and the Two rear window in/ops to Diagnose.
    Tyler/T-Unit
  4. #24 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    And I'm again forgetting that the back window needs replaced. The peeling blue tint looks like hell.
    Tyler/T-Unit
  5. #25 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Oil pan picked up today. Also got poly dog bone mounts. The square one.
    Tyler/T-Unit
  6. #26 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Oil pan is out. Took a solid half day of it fighting me to get it though. Also swapped out the dog bone bushings for the poly ones and got shorter dog bones with new rubber bushings.
    Sent from my XT1254 using Tapatalk
  7. #27 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Oil pan swap wrapped up. Found coolant coming in through a lifter. Looks like my planned valve cover gasket job just turned into a LIMG job.
    Tyler/T-Unit
  8. #28 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2017
    Internet
    For your rear windows being inop. Likely there's a broken wire in the rubber wire boot that goes into one of the rear doors. You can push/pull them a bit to see if you have broken wires. It's fairly common
  9. #29 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    I'll be doing some Investigating as soon as I get the thing roadworthy again.
    Tyler/T-Unit
  10. #30 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2017
    Internet
    I had Lucerne 18" Super rims
  11. #31 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Those look much better than what I've got.
    Tyler/T-Unit
  12. #32 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Got all the gaskets I need for the LIMG job. Just need time now. 26 hours when I punched out last night.
    Sent from my XT1635-01
    Tyler/T-Unit
  13. #33 Re: T-unit's boosted Buick AKA the Granny Slapper
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    This car makes me miss my regal.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  14. #34 Re: T-unit's boosted Buick AKA the Granny Slapper
    SE Level Member 2 Sweet's Avatar
    Apr 2017
    Hilliard, OH
    Quote Originally Posted by sampuppy1 View Post
    I removed the supercharged badge so people quit trying to race me.
    That badge is so small, I doubt anyone even noticed.
    My GS had those same chrome wheels as yours, and mine were junk too.
  15. #35 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Quote Originally Posted by BoostedPontiac View Post
    It's been sitting since I started the oil pan job. It's just been on my nerves. I tend to leave **** alone when it pisses me off. I'll have it on the road again soon. I don't have a/c in the truck. Coming home from work in this recent hot spell has been brutal.
    Quote Originally Posted by 2 Sweet View Post
    It's noticeable. It's the only really visible badge back there. I has some guy in a GTP turned and highway pull me after he hung out in my plans spot looking at the trunk.
    I had to put air in the tires again. Almost flat. I'll run them as long as I can. The rears are down to the wear bars. The fronts are better but not by much.
    Tyler/T-Unit
  16. #36 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Started the LIMG job. Need a few more gaskets and tune up stuff as well.
    Tyler/T-Unit
  17. #37 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Got it all back together this weekend. Sadly on the test drive, the dripping fuel line turned into a steady leak. So it is once again parked until I can get my hands on some stainless lines. Wedding is a few more weeks out. So I'll probably wait until after that. I need to focus on it more than anything right now.
    Tyler/T-Unit
  18. #38 Re: T-unit's boosted Buick AKA the Granny Slapper
    where you leaking? fuel line to the rail? if so you just need to pull the o rings out of the line and replace them.
    congrats on the wedding. have a blast.
  19. #39 Re: T-unit's boosted Buick AKA the Granny Slapper
    Mar 2016
    Under the car behind the back door. I'll find some stainless lines for it. It was bound to happen. They're original.
    Tyler/T-Unit
  20. #40 Re: T-unit's boosted Buick AKA the Granny Slapper
    thats the fuel filter area, theres a how to for replacing the line end and the filter to one with pinch clips on both sides so no more line nut to rust on there. the lit comes with some new line, http://www.grandprixforums.net/threa...25#post1379825
  1. 11 Second Granny
    By intrigue98 in forum Off Topic Discussion
    Last Post: 05-14-2012, 09:12 PM
  2. 99 Silver Granny GT
    By kenizzle36 in forum Members Rides
    Last Post: 08-01-2011, 11:40 AM
