Thread: 04+ aftermarket sway bars?
Results 1 to 5 of 5
  1. #1 04+ aftermarket sway bars?
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    I've been looking into new sway bars, and I've decided on the Dorman front sway bar with 97-03 LCAs. What I can't seem to find is any upgrades for the rear end. I have a Comp G, so I already have the GMPP one as far as I understood. Is there anything bigger, anything worthwhile to be had for the rear?
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  2. #2 Re: 04+ aftermarket sway bars?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Addco is the best. There's a couple threads going in this forum about it.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  3. #3 Re: 04+ aftermarket sway bars?
    Apr 2015
    Illinois
    They fit on an 04+? I was told they only fit 97-03 cars
  4. #4 Re: 04+ aftermarket sway bars?
    Aug 2013
    McDonald PA
    Quote Originally Posted by PaintChips97 View Post
    97-08 is the same rearend
  5. #5 Re: 04+ aftermarket sway bars?
    Apr 2015
    Illinois
    WELL. That makes things simpler, then! Thank you all!
  1. slp sway bars?
    By Classy Pontiac in forum Brakes/Suspension/Chassis
    Last Post: 07-01-2012, 09:11 AM
  2. Sway Bars
    By dert in forum Brakes/Suspension/Chassis
    Last Post: 02-09-2012, 11:56 AM
  3. sway bars
    By basballny2 in forum Brakes/Suspension/Chassis
    Last Post: 04-11-2010, 08:02 PM
  4. Sway bars
    By speedemongtp in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2009, 11:41 AM
  5. Sway Bars
    By RicerKiller in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2009, 12:14 AM
