Thread: New Struts question
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 83
  1. #21 Re: New Struts question
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    The quick strut is the whole assembly, no point in paying for springs you are going to replace. I would buy just the struts, add the lowering springs and mounting plates and install those as assemblies.
    Sent from my SPH-L720 using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  2. #22 Re: New Struts question
    GTP Level Member Grandprix202's Avatar
    Apr 2013
    Fowlerville
    Ahh gotcha Alright... I'll keep everyone updated. Should be ordering tonight or this weekend
    Sent from my SM-N900P using Tapatalk
    Representing all the N/A out there. Fastest stock N/A you will ever come across.
  3. #23 Re: New Struts question
    Apr 2013
    Fowlerville
    quick question. With my Tenzos that are 19's... I wouldn't need to roll my fenders right?
  4. #24 Re: New Struts question
    Depends on offset.
    04 Comp G.
  5. #25 Re: New Struts question
    Apr 2013
    Fowlerville
    I don't know anything other than 19 and 235 I believe
  6. #26 Re: New Struts question
    Kemmerer, Wyoming
    if you get lowering springs with 19's you might have clearance issues with the strut. there is a thread on wheels, and it will tell you the sizes of wheels you can run without having clearance issues. it might be a good idea to sell the 19's and put an oem wheel back on because the increased weight wears out the struts faster.
    I have the KYB AGX struts on my 2001 all around and really like them. at the drag strip I will put the firmness all the way up to 4 and the tires grab better. From what I've heard, they hold up the best when paired with lowering springs
  7. #27 New Struts question
    Depends on the offset then you may need roll the fenders.. Only way to find out for sure is to do it some guys will rub some guys won't just be prepared for when you do. You can always grab a Eastwood fender roller off eBay just in case or use a rubber mallet to work the fender slightly.
    04 Comp G.
  8. #28 Re: New Struts question
    Apr 2013
    Fowlerville
    Ahh alright... And there is no way in hell I'm selling these wheels haha. I have my stockers for winter time. I might just toss them on and see. And I have no future at the drag strip becuase I'm na
  9. #29 Re: New Struts question
    Your rims aren't going to wear out your struts any faster don't worry.
    04 Comp G.
  10. #30 Re: New Struts question
    Apr 2013
    Fowlerville
    Yea I'm not to worried about them wearing out. Mine are on original struts with 140k on them anything is better than what I have
  11. #31 Re: New Struts question
    Good. In riding on near blown struts myself
    04 Comp G.
  12. #32 Re: New Struts question
    Apr 2013
    Fowlerville
    Yea it's embarrassing through parking lots or where ever there are people becuase it makes SO much noise
  13. #33 Re: New Struts question
    Nov 2012
    Madison
    Quote Originally Posted by Grandprix202 View Post
    Your wheelios were on a 06GT with coilovers dude and he had it rolling with no rolling.
    Unless the car being red made a difference.
  14. #34 Re: New Struts question
    Apr 2013
    Fowlerville
    Lamo OK then I shouldn't have to worry
  15. #35 Re: New Struts question
    Keyword shouldn't.. But there's always that one unfortunate unicorn that will have to roll em.
    04 Comp G.
  16. #36 Re: New Struts question
    Aug 2013
    McDonald PA
    He def rolled his fenders lol. The rear your almost garunteed you have too
  17. #37 Re: New Struts question
    Chicago
    When I was debating this I opted not to get the quick struts. I believe I heard quality issues with that option. I went with KYBs including mounts. I reused my old springs. The air tools helped and you need to rent a spring compressor. It's a bit of work but definitely doable. Don't forget the alignment cause you are going to need one. 40k miles later and no issues.
  18. #38 Re: New Struts question
    Nov 2012
    Madison
    Your right he did.
    Good chance it was because he had it dropped aggressively on the coilovers.
    235/40/19 is basically the same diameter as 245/45/18 with the 18s being a little taller.
    I have a 40ET,not sure what yours are.
    I didn't rub with SSCs and 100,000 mile FE3s
  19. #39 Re: New Struts question
    GT Level Member Xorbex's Avatar
    Canada
    Not meaning to thread jack. What is the best adjustable for an 04+
  20. #40 Re: New Struts question
    Apr 2013
    Fowlerville
    I think i should be ok... Does anyone know what would need to be transferred over from the old struts... I know probably that rubber accordion thing and thsts all I can think of
  1. struts equal to GM konis struts
    By Dee23 in forum Brakes/Suspension/Chassis
    Last Post: 05-17-2015, 02:47 AM
  2. Struts, or struts and springs?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-14-2012, 07:23 AM
  3. question on struts
    By gtcoup in forum Brakes/Suspension/Chassis
    Last Post: 07-14-2011, 05:30 PM
  4. Question about prior gen struts
    By MissChelsea in forum Brakes/Suspension/Chassis
    Last Post: 03-30-2011, 04:21 PM
  5. Question on struts
    By basshead42 in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2009, 11:28 PM
