Thread: When braking cars pulls to left.
Results 1 to 14 of 14
  1. #1 When braking cars pulls to left.
    Dec 2013
    Niagara Falls Ontario
    Hi there. I've been doing some reading online and I have some idea whats going on, but I figured I'd run it past you guys and see what you think, So thanks in advance for any ideas.
    For the past while I've noticed that when I make a left turn with the window open I can hear rubbing from the front drivers side wheel, but wasn't sure what was causing it. I also have noticed that when I brake hard the steering wheel literally pulls left in my hand. I figure that they're related and that its a bad caliper, or possible the brake line/hose leading up to it is pluuged, however if my understanding is correct then if the left front wheel is the one with the bad caliper then wouldn't it pull right instead of left? Or maybe I'm wrong all together and you guys might have an idea, or two.
  2. #2 Re: When braking cars pulls to left.
    Feb 2013
    37.295091, -121.930053
    well it sounds like you have air in 1 side or bad caliper. i would check to see if the right is leaking if not then it has air
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: When braking cars pulls to left.
    Dec 2013
    But would air in the system lead to the rubbing sound when turning? I know it would lead to a lack of hydraulic pressure when braking, but that only explains 1 of the 2 symptoms.
  4. #4 Re: When braking cars pulls to left.
    Mar 2015
    Tampa, FL
    usually air in the system you will have a crappy pedal feel. Your right caliper could not be working and your left is doing all the braking or your left is starting to stick and working quicker to brake. Or you have hoses that are collapsed and not letting pressure thru properly. Calipers cheap, its always recommend to replace both when you do them
  5. #5 Re: When braking cars pulls to left.
    Enfield, CT
    It's a bad caliper. I assure you.
    Sent from my LG G3
  6. #6 Re: When braking cars pulls to left.
    Dec 2013
    That's what i think too. I figure the left caliper is sticking. I'll check it out tomorrow and see if I can see what's wrong exactly. It may just be the sliders. Thanks
  7. #7 Re: When braking cars pulls to left.
    id take that caliper off and clean and grease the slider bolts. and the inside of the caliper where the sliders bolts go in.
    it could also be a bad brake hose/ line to that caliper, they blow out in the inside clog up and dont let the brake pressure off the caliper.
  8. #8 Re: When braking cars pulls to left.
    Dec 2013
    Thanks. What is the best way to clean out the holes for the sliding pins? I would assume you dont want to use something abrasive and am unsure what cleaner is best suited for that grease.
  9. #9 Re: When braking cars pulls to left.
    brake cleaner and new grease put on the slider then work it into the caliper to re grease inside.
  10. #10 Re: When braking cars pulls to left.
    Sep 2014
    Worcester, MA
    You should do both sides. And bleed the brake fluid out of the caliper, it's probably overheated and junk.
  11. #11 Re: When braking cars pulls to left.
    Bastard Reptile's Avatar
    Kansas City, MO
    Check your caliper hose too. Sometimes a flap can tear off the inside of it, and keep the fluid pressure from the caliper from going back to the master cylinder.
    Get the car up on jack stands. Pump your brakes, and then get out to see if the caliper is sticking. If it is, crack the bleeder screw to see if any fluid comes shooting out. If it does, change the hose. If it doesn't, change the caliper.
  12. #12 Re: When braking cars pulls to left.
    Enfield, CT
    I would just change the calipers and hoses..
    Sent from my LG G3
  13. #13 Re: When braking cars pulls to left.
    good time to up grade to better brakes..good old F bodys come to mind.
  14. #14 Re: When braking cars pulls to left.
    Enfield, CT
    Word
    Sent from my LG G3
  1. Car pulls to the left
    By skeelo58 in forum Brakes/Suspension/Chassis
    Last Post: 11-07-2012, 01:31 PM
  2. Cop Pulls Out Gun On Motorcyclist
    By E IN v Y in forum Off Topic Discussion
    Last Post: 08-19-2011, 04:36 PM
  3. 2nd gear pulls...
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 12-31-2010, 11:01 PM
  4. Truck pulls
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 09-08-2010, 08:02 PM
  5. 00 gt pulls to right with acceleration
    By racerx217 in forum General Tech Discussion
    Last Post: 03-24-2009, 11:34 PM
