Thread: KYB GR2/AGX and SSC combo
Results 1 to 9 of 9
  1. #1 KYB GR2/AGX and SSC combo
    Minnesota
    I am thinking about lowering my Regal and looking for advice on this combo and particularly anything else I should "refresh" when lowering. I daily drive it so I'm not looking for a crazy drop, just something to clean up the gap with 18's. I guess you could say I picked out these two items from the sticky posts' and prior posts stating this was a common component, at least KYB struts.. If not, please steer me in another direction for either. Coil overs seem to be just a bit too much (new) to justify doing, and I've seen mentions of cheaper routes to get the same result.
    Thanks
    Please no hate on the wheels, they were ran in the winter from the previous owner so I sanded down the corrosion and plasti dipped them.
    Front
    Rear
  2. #2 Re: KYB GR2/AGX and SSC combo
    Nov 2012
    Madison
    Buy Matts SSCs and get some GR2s.
    You may as well put some new mounts in and get some Vinnie spacers.
    http://www.grandprixforums.net/threa...wering-springs
  3. #3 Re: KYB GR2/AGX and SSC combo
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I just lowered my car this winter on the combo you're looking at. My car is my daily driver year round in Michigan.
    KYB GR-2 and SSC Springs all the way around with 18" rims.
  4. #4 Re: KYB GR2/AGX and SSC combo
    Minnesota
    Quote Originally Posted by spazzz View Post
    Yeah, I saw that just posted. Thanks Spazz and Dan for the pictures.
  5. #5 Re: KYB GR2/AGX and SSC combo
    Dec 2008
    Lawndale, CA
    Vogtlands are another spring that lowers about an inch. They work great for daily driver.
  6. #6 Re: KYB GR2/AGX and SSC combo
    Minnesota
    Dan,
    Can you chime in with how many miles you roughly have on your setup? About to pull the trigger on struts but found some mixed reviews about it as to be expected, the issue I'm seeing is that AGX's aren't worth the extra money, but GR2/Excel's aren't necessarily for a lowered setup. Just looking for some reassurance if anything. Thanks!
  7. #7 Re: KYB GR2/AGX and SSC combo
    Dec 2008
    Lawndale, CA
    This is my brothers car on Vogtlands. He originally lowered the car with KYB's from this thread.
    http://www.grandprixforums.net/threa...-with-KYB-tech
    They lasted awhile and he is now on AGX's that ride better. He daily drives his.
    This one is more recent.
  8. #8 Re: KYB GR2/AGX and SSC combo
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I'm on ssc springs and gr2s, it's definitely not a bad ride.But if I could do it over, I'd go for agx adjustables.The gr2s do not dampen enough compared to the spring rate and you will get a little bounce.It's not horrible, but if you have the cash, get the adjustables.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  9. #9 Re: KYB GR2/AGX and SSC combo
    Minnesota
    Quote Originally Posted by goldgp View Post
    Thanks goldgp, that definitely helps. I have SSC's awaiting my strut decision, so I was looking for a similar setup but I wanted to justify the extra $200+ or so. Honestly, it was a last minute search that made me wary since the next argument ends up being "go coilover"
  1. rockers cam combo
    By fbm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2014, 05:54 PM
  2. 04+ Best Exhaust combo
    By crzystve42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 09:05 AM
  3. amp & sub combo... capacitor?
    By GTPjunkie in forum Audio, Security & Visual Electronics
    Last Post: 03-06-2010, 10:49 AM
  4. Will this combo work for mid 13's??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2008, 08:40 AM
