Thread: 1992 Grand AM Brake Bleeding help
Results 1 to 9 of 9
  1. #1 1992 Grand AM Brake Bleeding help
    Jan 2009
    Indiana
    I need to know how to bleed the brakes on a 1992 Grand AM. It has anti-lock brakes and I'm not sure if I need to bleed them differently than one would bleed "normal" brakes. If so, can someone give me some detailed instructions? If not, can someone let me know and I will bleed them like I would a car without anti-lock brakes.
    Thanks,
    Rick
  2. #2 Re: 1992 Grand AM Brake Bleeding help
    Jan 2009
    KY
    Did you figure it out?
    I dont know if this helps but on my GP 94, I bled the brakes via the master cylinder. It has antilock brakes.
    But I do have a manual for GAs as I have an 86, I can scan it for you.
  3. #3 Re: 1992 Grand AM Brake Bleeding help
    TDCRacing
    Guest
    Same as all brake systems. Start from the furthest caliper away from the MS and then the second furthest ect ect.
    If you changed the MS you will have to bench bleed that also before you put it on.
  4. #4 Re: 1992 Grand AM Brake Bleeding help
    SE Level Member beast3300's Avatar
    If you only replaced one brake line or wheel cylinder or caliper then you only need to bleed that wheel (as long as the mastercylinder didn't go empty.)
    rear right, then left rear, right front, left front.
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
  5. #5 Re: 1992 Grand AM Brake Bleeding help
    TDCRacing
    Guest
    Good point
  6. #6 Re: 1992 Grand AM Brake Bleeding help
    Jan 2009
    KY
    Quote Originally Posted by beast3300 View Post
    My memory is so terrible....I shouldnt post early morning after work...this is what I did in that order, the ms was the last thing i bled
  7. #7 Re: 1992 Grand AM Brake Bleeding help
    TDCRacing
    Guest
    The MS is the first thing you should bleed. You should bleed it out of the car using the supplied fittings and hoses (if purchased new)
    If you're having issues with the pedal pressure being low after you have already bled the brakes. Chances are that is it.
    Some other things to consider if there is no pedal pressure.
    Make sure you put the calipers on the right side of the car. If you switch them they will be upside down and the bleeder valve will be facing downward. Air rises. so they need to be facing upward so you can get all of the air out of the system.
    If there is low pedal pressure but the car still stops you either have air somewhere in the system or you need a new MS.
    Without the fittings in the box i'm not sure you CAN bleed the MS. What I did is go up to the parts place and bought a ms for my car took the lines out and returned it.
  8. #8 Re: 1992 Grand AM Brake Bleeding help
    Jan 2009
    Indiana
    I did do it the way you guys have posted and it seems to be working fine so far, thanks for the reply's
  9. #9 Re: 1992 Grand AM Brake Bleeding help
    TDCRacing
    Guest
    Glad we were able to help!
  1. 2002 Grand Prix - Right Rear Brake Leak
    By johngandersonjr in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2008, 09:43 PM
  2. 1992 grand Prix with loud lifters
    By smurfboy in forum General Tech Discussion
    Last Post: 09-25-2008, 12:03 PM
  3. 1992 Cadillac STS L67 Swap
    By Trannyman95 in forum Transplants
    Last Post: 12-13-2007, 04:34 PM
