you guys can tell me the likelihood of this theory.
When I bought my current GTP in the summer of 2013 it had worn brakes, they were not worn badly but the rotors were slightly warped. I had the rotors turned and the problem was fixed. I also had abs issues, and installed a rebuilt ebtcm, fixed a broken wire on the driver side wheel bearing and replaced the passenger side wheel bearing.
About 5 months ago the abs started going crazy, the pump would start modulating at random times for seemingly no apparent reason. I had the Stealership check the abs system and they said the passenger side wheel bearing was bad.
is it possible and/or likely that because of the abs pump/system going crazy the wheel bearing wore out faster, or is the more likely reason that the wheel bearing failed and resulted in the abs problems.
I have a bad habit of thinking the craziest most unlikely reasons for problems.
