Thread: Best Wheel Bearing?
Results 1 to 20 of 27
  1. #1 Best Wheel Bearing?
    Dec 2012
    Raleigh, North Carolina
    Hey everyone! So i need to replace one of my front wheel bearing and hub assembly's. Might just end up replacing them both for peace of mind. But I already know not to get a cheapo one off ebay. So i did a simple search on advanced auto parts website and got a few that all looked good. Not sure which would be the best for my 1997 GTP.
    http://shop.advanceautoparts.com/web...hedFrom=header
    ^There is the link to what i am looking at. Having trouble deciding between moog, timken or ac delco? ( Not sure about the driveworks and feq brands )
    Any advice is appreciated. Thanks!!
  2. #2 Re: Best Wheel Bearing?
    Rockauto Timken Part # 513179
  3. #3 Best Wheel Bearing?
    I would stick with either Moog/timken/skf since they come with a 3 year warranty IIRC at least the Moogs do
    Moogs the only one advance stocks so I would go with those especially since you can get for around $100 or so using a online coupon and warranty exchange would be a simple as stopping by the store with the defective bearing..
    I've had Moogs for awhile now and they do just fine.. Some will argue that timken are the best but last I checked you'll have to order those and that means if you do have to warranty them out guess what you'll have more then a hour of downtime
    04 Comp G.
  4. #4 Re: Best Wheel Bearing?
    Nov 2011
    NY
    Last I looked (ordered @ rock auto) the only one left offering 3 year warranty was Moog. Might be wrong, it's happened before (once or twice), but any of the three listed above would suffice.
  5. #5 Re: Best Wheel Bearing?
    Mercer, Pa
    Timken on Amazon is $97
    You can always go cheap so everytime you replace the cheap wheel bearings you can rotate your tires.
  6. #6 Re: Best Wheel Bearing?
    Jul 2010
    Coquitlam,BC,Canada
    I've gone through 3 SKF's in 4 years. I just replaced one with a Delco #513121 (5 year warranty). Only time will tell......
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Best Wheel Bearing?
    Mercer, Pa
    Saw Delco for $90ish on Amazon.
  8. #8 Re: Best Wheel Bearing?
    Jul 2012
    Chicago
    Moog, Timken, or Delco. Not always easy to find the latter without it being quite pricey.
    -Carl
  9. #9 Re: Best Wheel Bearing?
    precision auto has the same part numbers as timken and the same warranty.
    and they're cheaper.
  10. #10 Re: Best Wheel Bearing?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by sseilmnop View Post
    Sounds about right. I paid $125 Canuck Bucks.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Best Wheel Bearing?
    Mercer, Pa
    Quote Originally Posted by Bronco Boy View Post
    Always get one or 2 claim Timken SKF etc... Are junk. I bought cheap once, replaced them 3 times in under a year until out of warranty,, Bought from ZZP. My mistake.
    I've never replaced timken or Moog and I've had 4 Bonneville's in 10 years! Still own 2 of them. I'm sure it can happen but most people don't have problems
  12. #12 Re: Best Wheel Bearing?
    ive gone through 2 timkens under warranty. one was seizing up.
  13. #13 Re: Best Wheel Bearing?
    Jul 2010
    Coquitlam,BC,Canada
    Yup. I've been in the automotive parts business for over 25 years; I know how things work.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Best Wheel Bearing?
    I would get whatever your parts store offers with the best warranty.
    I had the cost of a wheel bearing down to about $6/each with how many I warrantied.
  15. #15 Re: Best Wheel Bearing?
    Buffalo
    MOOG cause it has a 3 year warranty vs the 1 year or no warranty by other brands
  16. #16 Re: Best Wheel Bearing?
    Nov 2013
    United States
    FWIW I would get a Moog or Delco bearing. I've used the cheapo ones and they didn't last a month (luckily, they refunded my money). I'm on Timken's now, but after a few autocrosses they're getting a little wobbly.
  17. #17 Re: Best Wheel Bearing?
    GT Level Member outonthetiles's Avatar
    Dec 2011
    Herkimer, NY
    I've had great luck with skf. Just make sure if you buy a better brand you are actually getting that brand. I've had ****ty Chinese bearings come in a skf box when I ordered off of eBay. Same thing happened to my dad.
  18. #18 Re: Best Wheel Bearing?
    Jul 2010
    Coquitlam,BC,Canada
    What's better, made in Korea? Or made in China?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  19. #19 Re: Best Wheel Bearing?
    GTP Level Member
    springfield IL
    I put some Timken's on my 2000 Grand Prix back in 09ish. No problems with them!!
  20. #20 Re: Best Wheel Bearing?
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    The only ones that seem to last longer then 6 months reliably is OEM ac delco bearings. I have only had one moog bearing last longer then 6 months.... which is weird because it has lasted almost 3 years now.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  2. Wheel rocking still... already changed wheel bearing. Ideas?
    By jmn in forum Introductions/Noob Questions
    Last Post: 09-30-2013, 09:27 AM
  3. ABS wheel bearing/hub on non ABS car?
    By Captain Bravo in forum Brakes/Suspension/Chassis
    Last Post: 01-01-2011, 03:15 PM
  4. Possible bad wheel bearing?
    By Cail in forum General Tech Discussion
    Last Post: 09-01-2010, 12:32 PM
