Thread: aluminum rear subframe
Results 1 to 18 of 18
  1. #1 aluminum rear subframe
    Jan 2015
    Syracuse, NY
    Googled and searched for the swap and what it comes off of. Does anybody know what car has the aluminum subframe for the REAR of the gp. remember reading about it and seeing a pic. TY
  2. #2 Re: aluminum rear subframe
    Kemmerer, Wyoming
    I've never heard of an aluminium rear subframe
  3. #3 Re: aluminum rear subframe
    Apr 2012
    Bancroft. Ontario, Canada
    are you talking about the FRONT sub frame? found in newer Impala's and GP's?
  4. #4 Re: aluminum rear subframe
    Enfield, CT
    My 06 still has the steel one and I've never seen a w-body with an aluminum REAR sub-frame aka rear crossmember
  5. #5 Re: aluminum rear subframe
    Antioch, IL
    Ill take a rear alum one if you find it!
    2009 Challenger SRT8
    Expert at being gay.
  6. #6 Re: aluminum rear subframe
    assuming your talking about a front one? i dont see there being any benifit of swapping the rear its not very big and cant weigh much for the back.
  7. #7 Re: aluminum rear subframe
    Antioch, IL
    go beat on your wife!
  8. #8 Re: aluminum rear subframe
    Enfield, CT
    Quote Originally Posted by 98WifeKillaVet View Post
    It hardly weighs anything and I know because I have one ready to give away
  9. #9 Re: aluminum rear subframe
    man bill really needs to change my name...........FML
  10. #10 Re: aluminum rear subframe
    Kemmerer, Wyoming
    how many vets are out there that have killed their wives?
  11. #11 Re: aluminum rear subframe
    hangover park IL
    probably quite a few that have wives that keep bringing home injured animals....
    no alum rear subframe available, the alum rear aztec subframe is sorta similar but in much the same way that my pecker is sorta similar to a 36" prybar
    ~James~ Psychotic Gearhead
  12. #12 Re: aluminum rear subframe
    Jan 2015
    Syracuse, NY
    thought I saw something on the rear a few years back. IDK maybe your right on the Aztec thing. I already got the front aluminum one and the front bumper support aluminum too.
  13. #13 Re: aluminum rear subframe
    Nov 2011
    NY
    Just get some alum. tube beams and make your own, be the first, be original. . .
    W-Body is not dead yet... Lolz!
    Heck, you might start a trend of gotta have's!
  14. #14 Re: aluminum rear subframe
    hangover park IL
    you CAN replace the rear bumper support beam with the alum aztek/redezvous front bumper
    you have to cut off and bolt on the steel brackets from the OEM rear bumper beam but you can drop weight that way
  15. #15 Re: aluminum rear subframe
    Enfield, CT
    Quote Originally Posted by Turbocharged400sbc View Post
    Are you dropping enough weight to make it worth it?
  16. #16 Re: aluminum rear subframe
    Antioch, IL
    100 pennies = a dollar so yes!
  17. #17 Re: aluminum rear subframe
    hangover park IL
    it doesn't drop a whole lot of weight but it does drop it in the most ideal area of the car
  18. #18 Re: aluminum rear subframe
    Jan 2015
    Syracuse, NY
    yes its worth it. I have a full m90 build going on. (have all pats) Just working on car. Gonna need a fuel tank brake/fuel lines and cables. I am already using the Aztec front support just not on rear. May as well swap that too.
  1. tricks to rear subframe bushings?
    By Vegas~Blown in forum General Tech Discussion
    Last Post: 04-22-2013, 07:02 PM
  2. Aluminum Subframe
    By ls1camino in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2013, 09:44 AM
  3. aluminum subframe
    By sdenton8 in forum Brakes/Suspension/Chassis
    Last Post: 07-24-2010, 10:33 PM
