Anyone use this kit from zzp yet? Looking for reviews. I want my 2007 to stop better. Will it mess with my abs and throw a light?
That zzp brake kit is like the cts-v brake kit except the rotor is slightly smaller. With 4 piston brembo brakes and 14 inch rotors my car stops amazingly. The negative is that the front is end will stop so much better than the rear that you will get more nose plow when you brake hard. That is why I upgraded to rear GXP brakes. The other negative is that with the 14 inch rotor and caliper you have to upgrade to 18 inch wheels which are not as good for ride comfort if you live in an area with bad roads.
this brake kit uses a 13.6" rotor and therefore I wonder if you can squeak away with a 17" rim.
There also using the rear calipers off the camaro for the kit. The piston size is slightly smaller. Then the cts-v/camaro as fronts
^ this... just another ZZP rip off of R&D that someone did first (ie. Drunkie). Just piece together your own kit.. cts-v front calipers, gt500 rotors, ss brake lines, bolts and washers and you will still be under what you pay for their kit I bet!
Thanks for the info guys. I forgot to mention I'm already running 18's. I may just go with the fbodies with slotted rotors and stainless lines. However I have heard of people having problems with caliper spread with the fbody setup?
How much for the gxp setup?
