Thread: rear "tie rods" question
Results 1 to 7 of 7
  1. #1 rear "tie rods" question
    SE Level Member InsaneGTP's Avatar
    Jan 2013
    largo
    I recently went for an alignment only to discover my rear tire rod looking thing on the drivers side is bent but I can't find any replacements online.....only the front ones show up are they the same thing or can someone link me to the proper place to buy them I'll need both the inner and outer pieces...any info is greatly appreciated. It's a 97 gtp coupe
  2. #2 Re: rear "tie rods" question
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    They're called front and rear lateral arms. Front meaning the one closer to the engine not on the front of the car. Search on rockauto and I'm sure you can find some stock replacements. Otherwise you can upgrade and find thicker ones like BMR that are on 3800performance.com and a couple other sites.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  3. #3 Re: rear "tie rods" question
    the long one thats from the body to the knuckle back there. is a trailing arms.
    the other two are laderal arms
  4. #4 Re: rear "tie rods" question
    Jan 2013
    largo
    Correction the ones in the pic are not what I am looking for. The part has an adjuster nut that actually goes onto the back of the wheel hub assembly.
  5. #5 Re: rear "tie rods" question
    Buffalo, NY
    Those are the lateral arms then
  6. #6 Re: rear "tie rods" question
  7. #7 Re: rear "tie rods" question
    Wow, surprised Scott didn't go into the 2000 regal folder on this one.
  1. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  4. "rear" wheel hub replacement question
    By 03GPGTOWNER in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2010, 10:39 PM
  5. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
