Thread: Strut making horrible noise
Results 1 to 5 of 5
  1. #1 Strut making horrible noise
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So I've had this cluncking going on in the rear for a long time. Couple years. Finally figured it out it was my strut when my dad was bouncing the car so I could look around. I replaced the stock struts about 2-3 months ago. These are KYB GR-2's with WBS springs on them. Band new mounts and everything. I built them myself but I believe I did them right and tighted everything down fine. Also used pogo washers. Thing is the stock struts were making the same exact noise on the same side. I'm not sure what would cause both to make the same cluncking noise. Took a video of outside the car and inside the trunk. The inside isn't bouncing either so the washers are doing their job.
    *edit* deleted videos from youtube since the problems been fixed.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: Strut making horrible noise
    check the sway bar end links if you have not already.
  3. #3 Re: Strut making horrible noise
    Buffalo, NY
    Damn Scotty, incredible. Tightened them up and the noise that's been causing me headaches and anxiety is gone. Thank you
  4. #4 Re: Strut making horrible noise
    damn that was one good guess lol
  5. #5 Re: Strut making horrible noise
    Buffalo, NY
    Haha I'd say so. I'll have another video up for you tomorrow that's a squeal
  1. Strut Options for making coilovers
    By PurpleGuy in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2014, 12:19 PM
  2. Some Kind Of Horrible Noise.
    By isukathalo93 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2012, 07:40 PM
  3. horrible noise
    By JesseBranham in forum General Grand Prix Discussion
    Last Post: 08-18-2012, 05:36 PM
  4. horrible time replacing strut mounts.. HELP
    By Linebacker in forum General Tech Discussion
    Last Post: 06-11-2012, 10:41 AM
  5. Engine making horrible noise.
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:24 AM
