Thread: Strut Options for making coilovers
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 99
  1. #1 Strut Options for making coilovers
    Never Never Land
    I'm going to be making another set of coilovers soon. Seems the SHO Koni inserts are no longer available? Also seems the Bilsteins are going away as well. Still on Rockauto but for $250+ a pop. What gives? Am I stuck with GR2's or are there other options?
    Also to add I'm not remotely interested in AGX's
  2. #2 Re: Strut Options
    Dec 2012
    troll land
    What yr car?
  3. #3 Re: Strut Options
    97 but they are mostly the same
  4. #4 Re: Strut Options
    Never Never Land
    Yea sorry. 97 GP. The car in my siggy
  5. #5 Re: Strut Options
    If RA has stock at 250, it's still fair game IMO.
  6. #6 Re: Strut Options
    Dec 2008
    Lawndale, CA
    Some guy on ls1tech has been saying that those struts on rockauto are not bilsteins but cheap chinese replacements. His words not mine. Supposedly he knows this because his friend or relative works at GM. Not even sure if this is true.
    You may be stuck with GR2's or I hate to say it AGX's.
    What about FE4 GR2's.
    http://www.grandprixforums.net/threa...-with-KYB-tech
  7. #7 Re: Strut Options
    Are they yellow, have a stupidly large shaft and come with a boot?
    I mean you all remember the new LT1 messiah right?
  8. #8 Re: Strut Options
    Oct 2011
    Puyallup WA
    Compg struts are a decent strut deff better the gr2 IMO...spose sway bar thing could be a issue
    08 G8 GT - exhaust Tune
  9. #9 Re: Strut Options
    Nov 2011
    NY
    Maybe all we need is the spec's on the diameter of the tube, length of travel and shaft length overall, find a similar strut (MonoTube) and just make a bracket to mount it to the knuckle...
    Yes the Bilstiens are hard to come by and RA had just 2 a few weeks ago, restocked? Lol... I'll have to look. Only other option is JY...
  10. #10 Re: Strut Options
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    IMO its kind of pointless to use anything originally intended for a gp. They're just too long and you sacrifice all of the travel to get even kind of low. I had tried to do some research on other model cars that may work and I think that info is somewhere in my build thread, I might have to go dig that up. But koni also makes sort of generic style inserts and I thought that they might work pretty well, but I never tried them. I also kind of think there isnt much benefit of making coilovers vs modifying existing ones. You might be able to find some decent ones on craigslist to cut up. Its really only the top and bottom mounts that matter so much, the length of the strut can vary some depending on how low you want.
    http://www.youtube.com/watch?v=_zPe0xZS_Og
  11. #11 Re: Strut Options
    Never Never Land
    In that vid is what i've been wanting to do. But I have no idea what insert i'd need to use.
  12. #12 Re: Strut Options
    Arizona
    I did this when my agx coilover blew out on my first conversions....I ordered the koni inserts and installed them. They blew out in a month of use at the same ride height my ride is on now. Clubgp has the writeup for it on the site. Under upgrades.
    Honestly we really need a way to just machine the strud rod down. The rest is cake
  13. #13 Re: Strut Options
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    These struts, GP style top mounts.
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  14. #14 Re: Strut Options
    Raleigh, NC
    ^^ Are those the ones for the lexus ES?
  15. #15 Re: Strut Options
    Nov 2012
    Frankenmuth, MI
    No, they're off something similar, not a Lexus. It's a secret
  16. #16 Re: Strut Options
    Camry... Or corolla I'm guessing
    04 Comp G.
  17. #17 Re: Strut Options
    Arizona
    Quote Originally Posted by WhiteLightningGTP View Post
    Its not like kuntzie didn't outline this already
  18. #18 Re: Strut Options
    Exactly. No point in keeping it a secret.
    04 Comp G.
  19. #19 Re: Strut Options
    I agree, share the info. How else do you expect the community to advance?
  20. #20 Re: Strut Options
    If I knew more I whole heartedly believe that some one just needs to measure the desired or targeted strut rod length, the amount of travel needed with out bottoming out and the actualy strut diameter is all that's needed.
    Strut diameter doesn't really matter either as long as it fit inside a gutted stocker and use bushings like some of the other DIY guys have done.
    Once the measurements are known just start calling companies one after another until the proper specs are found.
    Seems pointless to just "Hope" a set of modded coilovers from a different vehicle will work. They would have to be modded anyways. Just need the strut, nothing else.
  1. Replace KYB Strut-Plus strut with Bilstein?
    By nik12937 in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2014, 04:58 PM
  2. 08 GXP strut options
    By looong4 in forum Brakes/Suspension/Chassis
    Last Post: 02-08-2011, 12:42 AM
  3. Strut Options
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 06-25-2010, 05:45 PM
  4. 04+ Strut Options
    By ZR1Vette09 in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2010, 05:31 PM
  5. Monroe Quick Strut vs. KYB Strut Plus...definitive?
    By FRESCOLIO in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2009, 05:27 PM
