Original owner of a 99 GTP, 174K here. I have a clunk that seems to be coming from the rack area or more to the drivers side of the front of the car. The car only makes the noise if it has been sitting awhile. For instance, in the morning, when I back out of my garage, I go straight back, then cut the wheels to the right to head out. I always hear the clunk as Im rolling back and the wheel is turned right. What's puzzling is if I pull back into the garage and repeat the exact same maneuver, it is quiet. It seems to be the car needs to rest 5-10 minutes before it will clunk again. Driving it is fine, I hear no noise. In the last three years I have done struts, LCA's, all mounts, driver side CV axle, passenger side hub, sway bar and end links. This weekend I did the inner and outer tie rods. One thing that has me thinking rack is when I changed the boots on the inners there was an ounce or so of PS fluid in the boots, not sure if this is normal or not as the car is 15 years old and the boots have never been touched. Any ideas?
