Thread: Help Diagnose my clunk
Results 1 to 9 of 9
  1. #1 Help Diagnose my clunk
    Feb 2010
    Knoxville, TN
    Original owner of a 99 GTP, 174K here. I have a clunk that seems to be coming from the rack area or more to the drivers side of the front of the car. The car only makes the noise if it has been sitting awhile. For instance, in the morning, when I back out of my garage, I go straight back, then cut the wheels to the right to head out. I always hear the clunk as Im rolling back and the wheel is turned right. What's puzzling is if I pull back into the garage and repeat the exact same maneuver, it is quiet. It seems to be the car needs to rest 5-10 minutes before it will clunk again. Driving it is fine, I hear no noise. In the last three years I have done struts, LCA's, all mounts, driver side CV axle, passenger side hub, sway bar and end links. This weekend I did the inner and outer tie rods. One thing that has me thinking rack is when I changed the boots on the inners there was an ounce or so of PS fluid in the boots, not sure if this is normal or not as the car is 15 years old and the boots have never been touched. Any ideas?
  2. #2 Re: Help Diagnose my clunk
    Enfield, CT
    Maybe the ISS?
  3. #3 Re: Help Diagnose my clunk
    Feb 2010
    Knoxville, TN
    Thinking that as a possibility. Wasn't there a recall or something with the shafts? I remember reading something a long time ago about spraying the shaft with lithium grease to temp fix noises?
  4. #4 Re: Help Diagnose my clunk
    gardner,mass
    Only way the find out is to go over everything. I chased a clunk in mine for over a year and litterally replaced everything. Still have the clunk but found out its the front control arm bushings are good but weak so when i backup or move foward right the control arms hit the subframe. The control arms are new and were one of the first things i replaced.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  5. #5 Re: Help Diagnose my clunk
    Feb 2010
    Knoxville, TN
    I changed mine about 2 years ago, I'll have another look at them. Since my clunk happens only after sitting awhile, I'm thinking it could be a weight/settling kind of issue.
  6. #6 Re: Help Diagnose my clunk
    Banned
    Sub frame bushings. I changed everything in the front end and the clunk remained. The sub frame bushings were the last thing to do and it took care of my clunk. That many miles I know they need replaced.
  7. #7 Re: Help Diagnose my clunk
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by hshift View Post
    There wasn't a recall so much as a service bulletin. General Motors hasn't really gotten intermediate shafts right since it dumped rag joints.
    It sounds like the lube in the shaft may be dried.
  8. #8 Re: Help Diagnose my clunk
    Feb 2010
    Knoxville, TN
    Haven't had time to get underneath yet, but the sound DOES seem to be coming from the subframe bushing area. Will update when I can get under and have a look. Will also blast the ISS with grease, at least to see if the noise changes pitch or loudness.
  9. #9 Re: Help Diagnose my clunk
    Banned
    It will be hard to tell if they are failing visually. The rubber starts to separate from metal and you cant see it cause it is sandwiched in the sub frame. I would only put GM bushings in.
  1. Clunk...Clunk...Is driving me nuts!!!
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 04-13-2014, 01:26 PM
  2. I can't diagnose what's wrong with my car
    By metalexa1 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-03-2012, 05:21 PM
  3. Diagnose my problem please
    By skeelo58 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2010, 12:21 AM
  4. Impossible To Diagnose
    By 01Romano in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 06:19 PM
