Thread: Can't connect rack and pinion to steering
Results 1 to 12 of 12
  1. #1 Can't connect rack and pinion to steering
    Saskatchewan
    2008 Pontiac Grand Prix 3.8 litre. had to replace a high pressure steering hose. So I disconnected the steering rack to the steering wheel connection. lowered the subframe, put the new hose on. Now I'm having serious problems getting that back on ( rack to steering rod connection) is there a trick a special tool or something. The boot around that connection is way more beefy the previous years. worse comes to worse, gonna take off the sway bar, put the rack onto said connection, replace sway bar and jack the subframe onto the rack. Anybody got any better ideas.
  2. #2 Re: Can't connect rack and pinion to steering
    Get a friend and have them jiggle the wheel, its a pain in the ass to get that thing on. You could have gotten that line off without lowering the subframe that far.
  3. #3 Re: Can't connect rack and pinion to steering
    you need someone to wiggle/ move it the wheel back and fourth till it slides on the rack. no tool or trick, it flat can suck to get back on. truth is, you didnt need to take it off in the first place. the rack lines are right there asking to be unbolted.
    even if you lowered the sub frame the shaft will extend a good 4 inches.
  4. #4 Re: Can't connect rack and pinion to steering
    Saskatchewan
    dang it, guess I shoulda checked with someone who knew first. Well I'll give her a try in the morning.
  5. #5 Re: Can't connect rack and pinion to steering
    Haha Scotty ninjad you.
  6. #6 Re: Can't connect rack and pinion to steering
    Quote Originally Posted by slick2500 View Post
    you got me.....
  7. #7 Re: Can't connect rack and pinion to steering
    Arizona
    Take a flat head to spread apart the clamp where the shift slides in. It'll work fine after that
  8. #8 Re: Can't connect rack and pinion to steering
    Saskatchewan
    k, we got her together. No leaks, but we created another problem. The airbag light came on. Does anybody know how I can repair this.
  9. #9 Re: Can't connect rack and pinion to steering
    you done went and spun the steering wheel round and round didnt you..............
    time to buy a clock spring. used is far cheaper then new. new is like 160 ish.
  10. #10 Re: Can't connect rack and pinion to steering
    Saskatchewan
    I dunno, but my helper was singing, "round and round she goes, where she stops nobody knows!!". Yeah there's a car exactly like mine at the auto wrecked, guess I have another project.
  11. #11 Re: Can't connect rack and pinion to steering
    Mar 2012
    NC
    Quote Originally Posted by vagk1234 View Post
    Broke the spiral spring. Just replace the column. It's easier.
  12. #12 Re: Can't connect rack and pinion to steering
    that blows. but pretty funny. if you have radio controls you need one that also has radio controls.
    you have to pop the airbag off, then the steering wheel, then a ring clip, and its off, of course there 2 wires up top, radio and air bag to unhook, and 2 under the dash next to the obd3 port, then unhook it from the column. i changed mine wasn't all that bad. pretty easy really.
    if you get a junk yard part, make sure the donor cars wheels are straight. if not you'll have to re center the clock spring so it dont break again.
  1. Can rack and pinion cause wobble in steering?
    By teejay in forum General Tech Discussion
    Last Post: 04-14-2013, 06:45 PM
  2. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  3. Looking for a new rack and pinion.
    By QUICKSILVER462 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2012, 07:43 PM
  4. rack and pinion
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2011, 09:53 PM
