Thread: Strut busted through the frame in trunk...fixable?!
Results 1 to 16 of 16
  1. #1 Strut busted through the frame in trunk...fixable?!
    Mar 2012
    Hoffman Estates
    been hearing some nasty noises from the back of my 2000 gtp and pulled it into the garage today to find the strut had blown through the frame and into my trunk !
    my gtp has 240k miles on it and has more than just this problem currently and i was wondering if this is worth repairing, and how much ?
    or is it just new car time ?? ;[
  2. #2 Re: Strut busted through the frame in trunk...fixable?!
    Mar 2012
    Hoffman Estates
    pic.twitter.com/nT62EfZJwu
    the link to the picture of the right strut tower. the left strut is almost as bad
  3. #3 Re: Strut busted through the frame in trunk...fixable?!
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Can it be repaired? Sure, anything is repairable. Unless you have a welder and the skills to fix it, I would say time to replace. Depending on what else is wrong with the car, it might be time to replace regardless.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  4. #4 Re: Strut busted through the frame in trunk...fixable?!
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    The best ones are when it busts thought the back window......Very common problem in the rust belt.
    Go around to a few local shops and get quotes.....they ranges from $400-$2000. So it's very tough to say if it's worth it or not, that's all up to you.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  5. #5 Re: Strut busted through the frame in trunk...fixable?!
    Could you fix it, sure.
    But you won't want to pay the money to do so. It's a very common thing for cars in the rust belt, you car woulda needed to get fixed years ago to prevent that.
    At 240,000 miles, I'd part the car out and junk it.
  6. #6 Re: Strut busted through the frame in trunk...fixable?!
    that can be fixed. you buy a new top part for a mini van iirc then patch it in. you need some one who can weld for sure, or a body shop to fix it.
    or buy a car with a blown engine or tranny and swap your stuff over?
    post 122. strut rot repair work starts. http://www.grandprixforums.net/threa...ed-Build/page7
  7. #7 Re: Strut busted through the frame in trunk...fixable?!
    Feb 2009
    flintnasty MI
    its an easy fix if you want to run to the local steel yard for some junk, and grab a welder from harbor freight.
  8. #8 Re: Strut busted through the frame in trunk...fixable?!
    Mar 2012
    Hoffman Estates
    I work at a transmission supplier in Chicago, so welding no problem.. But the parts, where do I get that? Sawzawl to cut it out? Or get the new g6 GTP gxp....or is that Lil ponty, crap compared to our cars?
  9. #9 Re: Strut busted through the frame in trunk...fixable?!
  10. #10 Re: Strut busted through the frame in trunk...fixable?!
    Mar 2012
    Hoffman Estates
    What about the g6 GTP gxp?!
  11. #11 Re: Strut busted through the frame in trunk...fixable?!
    Mar 2012
    NC
    I kinda have pics of mine getting fixed...I drilled out my rear strut buckets, made a new steel plate, and welded and bolted it up there.
  12. #12 Re: Strut busted through the frame in trunk...fixable?!
    Jack it up until it's not through the trunk anymore and spray a bunch of expanding foam on top of that and let it dry then keep driving
  13. #13 Re: Strut busted through the frame in trunk...fixable?!
    Kansas
    In my honest opinion, I would say scrap the car as its probably not worth it. These cars are so common that you can pick up for a decent price. Like someone said buy one with a bad engine or trans for next to nothing, and swap your stuff over. Or just buy the G6.
  14. #14 Re: Strut busted through the frame in trunk...fixable?!
    clearly the redneck way of doing things. wheres the like button?
  15. #15 Re: Strut busted through the frame in trunk...fixable?!
    I'm all about cheaping out lol
  16. #16 Re: Strut busted through the frame in trunk...fixable?!
    Kansas
    And in my honest opinion, I don't think the "like" button will ever return.
  1. New to site. Need to repair rear strut mount area inside trunk.
    By nabber in forum Introductions/Noob Questions
    Last Post: 11-01-2012, 09:52 PM
  2. Coolant elbow leak...is it fixable???
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-17-2010, 11:29 PM
  3. busted oil pan
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2010, 01:32 AM
  4. Busted!!!
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 11-08-2009, 11:14 PM
  5. This is a good one! Fixable??
    By x1FastGTPx in forum Forum Bugs/Suggestions
    Last Post: 02-22-2008, 11:46 AM
