Thread: Brake Booster
Results 1 to 7 of 7
  1. #1 Brake Booster
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    Is there write up or videos on changing the booster. My car had a engine fire from my headers. Can't figure out how the booster goes on
    Sent from my Nexus 7 using Tapatalk
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  2. #2 Re: Brake Booster
    most bolt on from the inside the car, take the mater off the booster and the vac tube.
    inside un clip the rod from the brake pedal, and unbolt the 4 booster bolts from the firewall. should come right off.
  3. #3 Re: Brake Booster
    Jun 2011
    Watertown, SD
    That's the thing when mine fell off because of the fire there were no bolts.
    http://m.cardone.com/Part.aspx?partID=54-74825
  4. #4 Re: Brake Booster
    im not finding many pics of it. but this one looks to have a locking lever maybe of some sort.
    the booster needs to be tight and secure as that rod there hooks to the brake pedal, when you push the brakes, that rod pushes into the booster then the master.
    found at this link, its cheap at 25 bucks too. http://www.ebay.com/itm/97-98-99-00-...-/120962010752
  5. #5 Re: Brake Booster
    Jun 2011
    Watertown, SD
    Yea I got a new one just can't get it to stay put
  6. #6 Re: Brake Booster
    does that leaver move, and move anything else?
    seems you need to lock it to the fire wall some how. maybe its a put it in and turn it a little one way then it locks?
    if yours fell out during the fire. id check the new one next to the old one, then see if maybe the firewall is damaged.
  7. #7 Re: Brake Booster
    Jun 2011
    Watertown, SD
    I'll do that when I get home, I was looking in my service manual but can't find much on the booster
  1. WTB Smaller Brake Booster for turbo
    By ADrugDealer in forum Wanted To Buy - Parts
    Last Post: 12-02-2013, 09:06 AM
  2. Bad brake booster?
    By Pure2sin in forum General Tech Discussion
    Last Post: 01-27-2012, 11:58 PM
  3. Brake booster line
    By RedGrandprixgt53 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-26-2011, 10:57 PM
  4. 2001 GTP Brake Booster
    By Greg66 in forum Introductions/Noob Questions
    Last Post: 10-28-2009, 08:37 AM
  5. Brake Booster? Who has changed one?
    By sra_chipmunk in forum Brakes/Suspension/Chassis
    Last Post: 11-29-2008, 07:24 PM
