Thread: Kyb struts for 04+ comp g
Results 1 to 12 of 12
  1. #1 Kyb struts for 04+ comp g
    Apr 2012
    Michigan
    Just want to get anyone's opinions on the kyb gr2 rear struts for the 04+ Grand Prix comp g with the 17" rims, and if you got better springs or stuck with your old ones. Also does anyone know of a strut/spring assembly that will fit the 04+ w/17" rims?
  2. #2 Re: Kyb struts for 04+ comp g
    Nov 2012
    Madison
    Any garbage will work. What do you want, original ride?, lower? don't care?.
    I have an 04 compg with SSC springs( for 4,000 miles) on 90,000 original struts.
    I will only use the Delco FE3s for replacement struts, when I do it.
    You can use the GR2s and original springs, no sweat. It will be a small step down from the original struts, but they should work fine.
    Or get a strut/spring combo from Monroe if you really don't care. Most, if not all of us, would never dream of Monroe, except for the mounts.
  3. #3 Re: Kyb struts for 04+ comp g
    Dec 2008
    Lawndale, CA
    I have seen mixed reviews on kyb's. I would get the delco's on rock auto. Are you asking about lowering springs?
  4. #4 Re: Kyb struts for 04+ comp g
    Apr 2012
    Michigan
    I was thinking about getting either oem struts or the next best thing. I was going to get ac delcos but I am having a hard time finding the right ones for my car. Since I'm ordering online i want to be sure about the fit, 17" rim, fe3 susp, etc.
  5. #5 Re: Kyb struts for 04+ comp g
    Apr 2012
    Michigan
    Quote Originally Posted by The Guz View Post
    Yea I'm beginning to lean more towards acdelcos. And no I'm not lowering.
  6. #6 Re: Kyb struts for 04+ comp g
    Dec 2008
    Lawndale, CA
    From rockauto
    ACDELCO Part # 506623 {#88955413}
    STRUT,RR SUSP w/SPORT SUSP(FE3)
    ACDELCO Part # 506273 {#88955411}
    STRUT,FRT SUSP w/SPORT SUSP(FE3)
  7. #7 Re: Kyb struts for 04+ comp g
    Apr 2012
    Michigan
    So after struts, springs, and mounts should I buy a new boot kit for the struts or use the old ones? And is there anything I'm missing?
    Thanks for the replies and part numbers
  8. #8 Re: Kyb struts for 04+ comp g
    Reuse the old ones unless for some reasons yours are all torn etc.
    04 Comp G.
  9. #9 Re: Kyb struts for 04+ comp g
    Apr 2012
    Michigan
    Are you guys you using the stb's and has anyone used the don Rome brackets?
  10. #10 Re: Kyb struts for 04+ comp g
    Quote Originally Posted by BlackCompg04 View Post
    Yup and yup.
    Good product saves the hassle of drilling into the car...well worth the money.
    04 Comp G.
  11. #11 Re: Kyb struts for 04+ comp g
    I'm running gr2's on my comp g with an unknown spring that lowered my car about 2"
  12. #12 Re: Kyb struts for 04+ comp g
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    I'm running 2004 CompG Springs with KYB GR2 339015's and 339148's. These are the FE4 (Special Handling Package) spec struts.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  1. what struts with comp-g springs?
    By papaspanky in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2012, 10:18 PM
  2. Comp G Struts
    By 06grandprix93 in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2011, 04:25 PM
  3. quick struts for 04 comp g?
    By mike81 in forum Brakes/Suspension/Chassis
    Last Post: 11-27-2009, 04:10 AM
