Thread: Rear Caliper Banjo Bolt
Results 1 to 5 of 5
  1. #1 Rear Caliper Banjo Bolt
    Dec 2011
    Missouri
    What, if anything, is different between a rear caliper with M10-1.5 inlet threads compared to one with M10-1.0 threads, obviously, other than the threads? My car ('04 GTP Comp G) had a M10-1.5 caliper on it, and I ordered one and painted it before I figured out it was tapped for M10-1.0 threads? Visually, they look the same other than the inlet hole. I'm hoping I can fix my F-up with buying a new bolt instead of a whole other caliper. PLEASE HELP, car is apart and having to borrow wife's car
    Thanks!
    2004 Grand Prix GTP Comp-G
    2002 Grand Prix GT-Sittin' in a junk yard somwhere-RIP
  2. #2 Re: Rear Caliper Banjo Bolt
    The thread pitch is the key here. A 1.0 is not going to thread into a 1.5 hole. Look close at the two next to each other at the threads. the 1.5 will be much further spread apart than the 1.0
  3. #3 Re: Rear Caliper Banjo Bolt
    Dec 2011
    Missouri
    I understand about thread pitch. I am a machinist and work with threads everyday. This morning I ordered a M10-1.0 bolt the same length as the M10-1.5 bolt I have. What I need to know is will this caliper function the same as what I took off, after I use the correct bolt to thread into the caliper. I didn't know if GM, in their infinate wisdom, made something else queer about the caliper when they changed the thread pitch.
  4. #4 Re: Rear Caliper Banjo Bolt
    Ahhhh think I misread a little.
    I'd be double checking the caliper, that's odd that it has a different pitch. For your actual question, I'd know the same amount as you. If everything seems to line up properly, then I'd assume yes and give it a try.
  5. #5 Re: Rear Caliper Banjo Bolt
    Dec 2011
    Missouri
    It bolted onto the car just fine......I had it on the car before I even figured out there was a problem. I went to a local parts store yesterday that had both versions on the shelf and looked them over and I couldn't see anything different. But just because I couldn't see anything didn't mean they didn't change anything inside. At this point I'm going to try it because I can't take it back because I already painted it (after I took ALL of them off to paint them so they match) so I don't have much to lose at this point. Everywhere I looked, fine thread calipers are more expensive than coarse thread ones by $10-$20 for some reason.
  1. Looking for F-body Banjo Bolt source
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2015, 03:44 PM
  2. Need Caliper Bolt torque value
    By PlayingMechanic in forum Brakes/Suspension/Chassis
    Last Post: 02-27-2012, 10:32 PM
  3. Brake Caliper to Hub bolt
    By GPGT4dr in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2012, 03:57 AM
  4. Stubborn caliper bolt
    By Teancum in forum Brakes/Suspension/Chassis
    Last Post: 07-18-2011, 05:40 AM
  5. Caliper pin bolt
    By IndeedSS in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2008, 12:29 PM
