Thread: drilled/slotted rotors w/ceramic pads...good idea?
Results 1 to 11 of 11
  1. #1 drilled/slotted rotors w/ceramic pads...good idea?
    Sep 2013
    Frederick,MD
    so at 75k miles i appear to need some brake work. front rotors a tad warped and pads are all but shot,rear is decent but nothing to jump up and down about for sure.was thinking bout the dreilled/slotted rotors and some decent ceramic pads as a replacement all the way around.i only drive it about 3 to 5k's a year...i see where monroe pads get good reviews.. which i was surprised about...plus this would look cool as well..
  2. #2 Re: drilled/slotted rotors w/ceramic pads...good idea?
    GTX Level Member blackflag's Avatar
    Virginia
    I have them. The only benefits are;
    1. Your spending just about the same price for regs
    2. They look awesome
    3. they make an awesome sound when braking
    otherwise, meh.
  3. #3 Re: drilled/slotted rotors w/ceramic pads...good idea?
    this would be a good time to upgrade to F body calipers and rotors for the front. and some ss lines for all 4 calipers.
    i got ceramic pads and slotted rotors all around, with the f bodys up front. night and day over stock stopping power.
  4. #4 Re: drilled/slotted rotors w/ceramic pads...good idea?
    Virginia
    agreed as long as you figure out the spare tire issue.
  5. #5 Re: drilled/slotted rotors w/ceramic pads...good idea?
    If youre staying stock, just know there is no difference in stopping power for drilled/slotted rotors (if anything there is less). I am 100% with with this guy ^^^^ if you have to replace them anyway, might as well get something that will actually function better AND look cool (assuming you go with drilled/slotted). Fbody kits, especially used, are not that pricy anymore.
  6. #6 Re: drilled/slotted rotors w/ceramic pads...good idea?
    Quote Originally Posted by BlackFlag View Post
    you carry the stock jack, and a bottle jack. jack up the one side of the car and take the back tire off, and put it on the front, put the spare on the back. problem solved for 20 bucks. or less.
    your trans will hate you for driving with a spare on the front anyways.
  7. #7 Re: drilled/slotted rotors w/ceramic pads...good idea?
    Virginia
    mmmm thats how my dad f'd his trans LOL!
  8. #8 Re: drilled/slotted rotors w/ceramic pads...good idea?
    Sep 2013
    Frederick,MD
    thanks for the input,sounds like this will be a good combo. i will look into the calipers your talking about as well.i will keep you posted and thanks for the info..
  9. #9 Re: drilled/slotted rotors w/ceramic pads...good idea?
    Sep 2013
    Frederick,MD
    UPDATE... been about a month or so and about 500 miles and all is well with the ceramic pads and the power stop rotors.ive noticed the brakes grab faster..not sure if that means they are better or not...and the monroe pads that i questioned..are doing great with no dust or anything..come to find out my dad has the monroe ceramic pads on his truck and has a butt load of miles on them...i think they are made in canada if thats of intrest to anyone?
  10. #10 Re: drilled/slotted rotors w/ceramic pads...good idea?
    Pennsylvania, USA
    I was going to go with some Wagner Thermo-Quiet ceramics, due to the low amounts of dust and noise. How loud have those Monroe pads been?
    It's the only reason I'm steering away from semi metallics at this point, they always grind here and there and just sound ****ty in general when braking.
  11. #11 Re: drilled/slotted rotors w/ceramic pads...good idea?
    Sep 2013
    Frederick,MD
    the monroes are shockingly quiet! i was skeptical at 1st knowing they werent a high dollar pad..but like i say so far so good!
  1. Powerstop drilled and slotted rotors, any good?
    By WhiteGT in forum Brakes/Suspension/Chassis
    Last Post: 10-06-2012, 10:23 PM
  2. New drilled and slotted rotors, ceramic pads (ebay)
    By Peacher213 in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2012, 01:18 AM
  3. Used Drilled Slotted Rotors?
    By Confusingboat in forum Tires & Wheels
    Last Post: 09-23-2010, 07:20 PM
  4. Can drilled and slotted rotors be turned?
    By corsagtp in forum Brakes/Suspension/Chassis
    Last Post: 04-11-2010, 01:55 AM
