Thread: Grand Prix 2008 Base with clunk noise
Results 1 to 11 of 11
  1. #1 Grand Prix 2008 Base with clunk noise
    Mar 2013
    Canada
    It sounds like a clunk noise or metal hitting when going over bumps but not all the time, it is hit and miss and if I go over speed bumps no issues its only when I'm going at a good speed and hit a bump on the road that I hear it. I replaced front and rear struts and Mounts as they were over do, steering gear shaft as it was leaking, rear stab links, this was done all last week, front outer tie rods was done last year. Anything else that can be the issue? The sound is coming from the rear. Also I can I determine what part is it, Thanks
  2. #2 Re: Grand Prix 2008 Base with clunk noise
    Spare tire locknut is tight?
    Just to check things off.
  3. #3 Re: Grand Prix 2008 Base with clunk noise
    Dec 2012
    Where 4T65E's were born
    The rear doesn't often clunk, how many miles?
    And you mention you did rear sway bar links, I hope you did the fronts too as they go bad much sooner, and make lots of noise when they do.
    Sold.
  4. #4 Re: Grand Prix 2008 Base with clunk noise
    Mar 2013
    Canada
    I checked the spare tire but I didnt take it out of the trunk and then drive around, however it was secured pretty good. The sound is hit and miss does happen all the time. Not sure If I replaced the front sway bar as I bought the car used in 2010 but just last month the mechanic told me the things I need to replace hence why I did the change, the car has about 75000 miles but it does not have any play in the front, I changed the back because it have play. I cant define the sound not sure if its a clunk or not but what rear sounds does it normally make when there is a problem?
  5. #5 Re: Grand Prix 2008 Base with clunk noise
    what part are you calling a steering gear? ^^ cause only the rack, or the pump, or lines can leak.
    check the ball joints, and that all the exhaust hangers are in place.
  6. #6 Re: Grand Prix 2008 Base with clunk noise
    Mar 2013
    Canada
    It was the rack that was leaking, are the exhaust hangers easy to see?
  7. #7 Re: Grand Prix 2008 Base with clunk noise
    between the cat and res are two round rubber hangers, then theres 2 more along the Y pipe, and 2 at each muffler.
  8. #8 Re: Grand Prix 2008 Base with clunk noise
    Mar 2013
    Canada
    I also have another issue and its certainly coming from the driver side brakes. When I apply the brakes and come to a complete stop and then move up slowly and then brake again I here this clunk/pop noise, I did re-lube the pads last month and that didnt help, the pads and rotors are new as I replaced them 3 months ago and when I did I didnt have any issues until recently. Can it be the caliper, backing plate etc... I think it started to happen when my wife drove with the parking brake on for like 10 seconds or so, dont know if that caused the issue or not. Is there anything else I can check, as mentioned in my earlier post the other clunking noise when going over the bumps is rarely there so im focusing on the front end noise now.
    Thanks
  9. #9 Re: Grand Prix 2008 Base with clunk noise
    you need to just give your whole front end a look over, sway bar bushings, end links, ball joints, all that stuff can make sounds on you.
  10. #10 Re: Grand Prix 2008 Base with clunk noise
    GTP Level Member
    Aug 2012
    st louis park, MN
    I also have a 2008 grand prix and am chasing a few clunks of my own. Since you already did the rear stabilizer links, the only other thing I can recommend checking from personal experience, is that the emegency brake line is not loose. I had a mean rattle coming from the back and it turned out to be the emergency brake line near the right rear tire; there was a mount back there that was no longer secure and making tons of noise over bumps. It was more of a rattle though, not a clunk as you are looking for. I just threw a couple small zip ties to re-secure and it's been fine since.
    I also have a couple clunks in my front end I haven't been able to track down. Glad to know I'm not the only one chasing noises.
  11. #11 Re: Grand Prix 2008 Base with clunk noise
    Mar 2013
    Canada
    Hi stocker
    Its funny you said it was the ebrake few days ago I checked it and it was loose here is my other post http://www.grandprixforums.net/showthread.php?t=83326
  1. 2008 Grand Prix - Base
    By 67GTONUT in forum For Sale - Vehicles
    Last Post: 08-24-2013, 11:21 AM
  2. 2008 grand prix (base) running hot.
    By unzip2000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2013, 11:42 AM
  3. Bone stock 2008 Grand Prix (base) 1/4 mile E.T. & MPH ?!?
    By danieldepetro in forum General Tech Discussion
    Last Post: 06-15-2010, 12:42 AM
  4. 2008 Grand Prix Base Wheels
    By ajaxjblue in forum Tires & Wheels
    Last Post: 10-05-2009, 12:33 PM
  5. 2008 Pontiac Grand Prix Base Edition
    By MarkedAchilles in forum Audio, Security & Visual Electronics
    Last Post: 01-28-2009, 11:49 AM
