Thread: C5 Calipers + 06 Impala Brackets?
Results 1 to 17 of 17
  1. #1 C5 Calipers + 06 Impala Brackets?
    Oct 2011
    Puyallup WA
    So I picked up some C5 Calipers and was reading about how the 06+ Impala calipers are the same Fbody except for being cast instead of Alum...So I am wondering if I can buy some 06+ brackets so I don't have to retap Fbody brackets to install my new brakes?
    08 G8 GT - exhaust Tune
  2. #2 Re: C5 Calipers + 06 Impala Brackets?
    Oct 2011
    Puyallup WA
    Anyone?
  3. #3 Re: C5 Calipers + 06 Impala Brackets?
    SE Level Member velocitytech's Avatar
    Apr 2015
    MartinsFerry,OH
    have you ever figured this one out?
    99 GTP L26 Rods,XPZ, 3.1 MPS, Gen5, Intense Trans
  4. #4 Re: C5 Calipers + 06 Impala Brackets?
    SE Level Member CadVetteStang's Avatar
    Jun 2014
    Little Rock, Arkansans
    You're not going to need to retap anything if you buy the little bushings that work as spacers between the bolt and bolt hole. I think they only cost a couple of bucks a piece. I think the manufacturer isMaster Car or McMaster or something like that. One or more of the brake stickies has that info; I just can't remember the specifics.
    Am here now researching something like that now.
  5. #5 Re: C5 Calipers + 06 Impala Brackets?
    Buffalo
    Where did you find that info btw?
  6. #6 Re: C5 Calipers + 06 Impala Brackets?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    As we speak Im putting 06 impala calipers and brackets on my 04 everything bolts directly no drilling or other bs
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  7. #7 Re: C5 Calipers + 06 Impala Brackets?
    GXP Level Member
    Mar 2015
    Tomball
    Yeah 06' and up Impala front brakes bolt on with no problem just rotate the banjo fitting to clear the bleeder screw. I did it a couple of weeks ago. What are C5 calipers? Like corvette C5?
    Jeff
  8. #8 Re: C5 Calipers + 06 Impala Brackets?
    Yup as in corvette c5.. Aka fancy fbodies even though I think the pistons are slightly different.
    04 Comp G.
  9. #9 Re: C5 Calipers + 06 Impala Brackets?
    Jan 2013
    leavenworth ks
    Interesting Im loving my 06 impala brakes and steel braided lines there fcking amazing the stopping power!! Give my self whiplash I think lol
    Sent from my SM-S820L using Tapatalk
  10. #10 Re: C5 Calipers + 06 Impala Brackets?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by REDCRAPGP View Post
    That is interesting, Will it accept a larger rotor, or jus the 11.7-12.0"
    Jeff
  11. #11 Re: C5 Calipers + 06 Impala Brackets?
    Jan 2013
    leavenworth ks
    My advise don't mix and match stick with one set up and go with it
  12. #12 Re: C5 Calipers + 06 Impala Brackets?
    GXP Level Member
    Mar 2015
    Tomball
    I already have 07' Imp setup on my car, I am asking for the future, thanks for the advice.
    Jeff
  13. #13 Re: C5 Calipers + 06 Impala Brackets?
    I believe just 12" like the Fbodys
    04 Comp G.
  14. #14 Re: C5 Calipers + 06 Impala Brackets?
    Jun 2014
    Vette C5 calipers have smaller pistons so they fill quicker than F-body calipers. This makes the brakes react quicker with less peddal. You stop faster and don't get the soft brake peddal that the F-body will cause ( unless you also use an F-body master cyl.)
    BTW ( F-body calipers are aluminum from 97 up and )maybe a few more years too.
  15. #15 Re: C5 Calipers + 06 Impala Brackets?
    GXP Level Member
    Mar 2015
    Tomball
    That's interesting as well I have always felt that the pedal has more travel than is should and after comparing the standard GP single piston and the Impala Dual piston I figured the volume displaced would be slightly more than the single. I would like a pedal that is a Little firmer would a F-body or is there a better MC to use?
    Jeff
  16. #16 Re: C5 Calipers + 06 Impala Brackets?
    Feb 2013
    Missouri
    Quote Originally Posted by CadVetteStang View Post
    98-02 are all aluminum, but they are gravity fed aluminum. The C5s are pressure cast, along with the smaller pistons, those are the major differences.
  17. #17 Re: C5 Calipers + 06 Impala Brackets?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by wa04compg View Post
    I'm not sure if C5 calipers will bolt to 06+ Imp caliper brackets. The calipers are a bit more different than just material... the F-bodies have larger diameter pistons, the walls of the pistons are thicker, and have cooling fins. Can't tell you for sure if the brackets are interchangeable though. I installed 06+ Imp calipers on my 04SS, going to put F-body calipers on my LS. (Pretty much just using what the local junkyard has available) I will be tapping my F-bodies shortly, already have the appropriate drill bit and tap...just need to get off my ass and do it.
    If you decide to go the F-body route and drill/tap, I'll let you borrow them. If you need F-body brackets, I can get them cheap at my local yard.... might be awhile before I can get back out there, though. Just got done robbing a police impala of it's sway bars and trailing arms, lol
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. I want GXP Rear Calipers/Brackets
    By Dtrick22 in forum Wanted To Buy - Parts
    Last Post: 08-29-2013, 11:11 PM
