Thread: Bilstein Coilovers
Page 8 of 8 FirstFirst ... 678
Results 141 to 145 of 145
  1. #141 Re: Bilstein Coilovers
    Arizona
    I was thinking of punching out the studs on the plate and drilling on the plate so you could have caster and camber adjustment by just removing the mount bolts and moving back or side to side and and put the bolts back in
  2. #142 Re: Bilstein Coilovers
    hangover park IL
    with my thoughts you would slot the strut to knuckle upper hole and use the clamp plates to adjust for the camber you want and then weld the plates to the strut and that finishes off your knuckle side.
    from there you can use a standard camber bolt for small adjustments.
    the top would just be moved in far enough that with coilovers you can get an extra half to three quarters of an inch clearance to some fat rubber
    ~James~ Psychotic Gearhead
  3. #143 Re: Bilstein Coilovers
    hangover park IL
    the beauty of laying the strut back at a higher angle. . is the rate of positive camber gain from level control arms (lowered) compressing is slightly neggated
  4. #144 Re: Bilstein Coilovers
    hangover park IL
    haha
    i found my sn95 cc plates so i can finally cut em to weld em in the TRs oe upper plates.
    looking at the stack height im probably going to end up with the strut rod close to .5" higher than oe. but that can be adjusted by the adaptor sleeves/collars
  5. #145 Re: Bilstein Coilovers
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by 91parkave View Post
    I was going to do this then take another plate, cut out the whole center, use that to hold the bolts. I got one plate cut out, then I just decided to reem the strut holes since it's easier to do. Somehow I gave it enough on each side and identical to where the guy just had to adjust for toe.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  1. Given up on coilovers
    By carcrobatics in forum Brakes/Suspension/Chassis
    Last Post: 06-10-2013, 12:33 AM
  2. Bilstein HD?
    By Akuch26 in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2013, 10:07 AM
  3. Bilstein Rear Struts...
    By Alsafi92 in forum Wanted To Trade
    Last Post: 01-29-2013, 04:11 PM
  4. agx vs bilstein
    By 06PONTGP in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2012, 08:59 PM
  5. Bilstein offered for 97-03??
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 10:30 AM
