Thread: Went to Les Schwab for an alignment.... need your guys help
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Went to Les Schwab for an alignment.... need your guys help
    Dec 2012
    Where 4T65E's were born
    Well only 3 reasons to replace a hub. 1. Wheel speed sensor problems, 2. Play in the hub, 3. Noise from the hub.
    If theres no noise or speed sensor issues, pull on the wheel with it jacked up to check for play. If there's none then it's fine.
    Sold.
  2. #22 Re: Went to Les Schwab for an alignment.... need your guys help
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Thanks for that ill put it up in the air and check, as it stands there is no noise or speed sensor issues.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  3. #23 Re: Went to Les Schwab for an alignment.... need your guys help
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Quote Originally Posted by h0wl0ngcanitbe View Post
    Super easy to change hubs search the how to's , and BTW cover up you phone number next time
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  4. #24 Re: Went to Les Schwab for an alignment.... need your guys help
    This place sounds like Tires Plus, took my black car in to get some tires they come out with a ~$1600 list of things that need to be replaced, 2 lower control arms for $250 each 2 tie rod ends $180 each $426 for the tires plus ~$400 for labor. But the alignment was free with the purchase of the tires. I told them no, priced out all the parts for less than what they wanted to charge me for labor.
  5. #25 Re: Went to Les Schwab for an alignment.... need your guys help
    Marysville WA
    Quote Originally Posted by slick2500 View Post
    Heh im a licensed Realtor, my numbers everywhere!
  6. #26 Re: Went to Les Schwab for an alignment.... need your guys help
    ^what?
    Sent from my LGL75C using Tapatalk 2
  7. #27 Re: Went to Les Schwab for an alignment.... need your guys help
    Marysville WA
    ^what?
    Im self employed and run a large youtube business, my phone number is everywhere on the internet! I dont mind my number floating around I get a lot of calls.
  1. How's my alignment look?
    By LS1GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2013, 07:45 PM
  2. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  3. Alignment
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2011, 10:39 AM
  4. Alignment
    By matt5112 in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2010, 03:51 AM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
