Thread: Strut choice for lowering springs
Results 1 to 20 of 25
  1. #1 Strut choice for lowering springs
    GT Level Member kking89's Avatar
    st.louis
    what kind of struts do you guys think i should get? I have ebiach lower springs. its supposed to be 1.5-1.7 inch drop. I was thinking about getting KYB AGX struts from Rockauto.com. Its about 150-170 for each end set. Also do you guys think i will rub when i lower my car? i have 18 inch wheels on 245/45 tires
  2. #2 Re: Strut choice for lowering springs
    Oct 2011
    Puyallup WA
    What the offset on your wheels? That will determine if you will rub or not
    08 G8 GT - exhaust Tune
  3. #3 Re: Strut choice for lowering springs
    st.louis
    cant exactly remember. i think its 35 maybe 36mm offset. they are 18x8 sport edition wheels. Look very similar to the Kv5, but they no longer make my wheels. I dont remember the name of the wheels
  4. #4 Re: Strut choice for lowering springs
    It's possible that it will rub in the back..it's a simple fix roll your fenders.
    04 Comp G.
  5. #5 Re: Strut choice for lowering springs
    Florida
    I'm running 18x9.5 with 245/45/18's 28mm offset on SSC lowering springs, and I've got a little room to spare. Should be plenty fine running the same size wheels/tires with the 35mm offset
  6. #6 Re: Strut choice for lowering springs
    04s tend to drop a bit more then the previous gen Squid!
    It's simple anyways.. Heat gun, mallet or wooden back and a hour of your time.
    04 Comp G.
  7. #7 Re: Strut choice for lowering springs
    Dec 2008
    Lawndale, CA
    Get the AGX's. If the drop was minimal you could get away with GR2's.
  8. #8 Re: Strut choice for lowering springs
    st.louis
    i got a 03. yah i know i could roll my fenders. my brother had just done it he may still have the roller the hooks on to your wheel hub. but i would rather not want to cuz with my luck i would crack the fender.
  9. #9 Re: Strut choice for lowering springs
    st.louis
    yah i plan to get AGX, with some anti pogo bushings. anything else you recommend to make the ride better?
  10. #10 Re: Strut choice for lowering springs
    st.louis
    More Information for KYB 734058 these are the struts right here
  11. #11 Re: Strut choice for lowering springs
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    Go to partsgeek.com for the AGX struts. $445 SHIPPED. and here is a $15 coupon code for an extra discount(SAVE15). your welcome
    Rockauto has them listed for 110 per front strut, and 120 for each rear. Plus shipping.
    dont buy the GR2s. They are garbage.
  12. #12 Re: Strut choice for lowering springs
    st.louis
    well if the ones i linked are the GR2 then partsgeek has the same exacts one
  13. #13 Re: Strut choice for lowering springs
    I'd run gr2s. You're gonna blow agx just as quickly.
    But apparently I'm a rebel.
  14. #14 Re: Strut choice for lowering springs
    st.louis
    are Gr2 cheaper? the AGX has anti dampering control on the outside like coil overs would for height.
  15. #15 Re: Strut choice for lowering springs
    they don't have ANYTHING adjustable for height. even a knob on a coilover like that wouldn't adjust height. height is adjusted by moving the springs OR the strut body, NEVER the knobs.
    it's rebound/compression damping adjustment.
    and yes, GR2 are cheaper. they're a stock replacement strut.
  16. #16 Re: Strut choice for lowering springs
    Arizona
    Late response but for the money for agx you might as well go bilstein
  17. #17 Re: Strut choice for lowering springs
    Jan 2009
    Tallahassee, FL
    I'd get spacers for the mounts for Eibachs
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  18. #18 Re: Strut choice for lowering springs
    GTX Level Member blackflag's Avatar
    Virginia
    gr-2s. agx is not worth the money and blow fairly quickly.....
  19. #19 Re: Strut choice for lowering springs
    Virginia
    So do gr-2's for that matter. We have shhit choices for our platform. Might as well spend less money
  20. #20 Re: Strut choice for lowering springs
    Arizona
    Quote Originally Posted by BlackFlag View Post
    My coilovers are doing great with the bilsteins not so much the koni
  1. lowering springs
    By CMURDAx in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2010, 07:55 AM
  2. lowering springs
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2009, 02:16 AM
