Thread: Would You Think It's The Steering Gear?
Results 1 to 9 of 9
  1. #1 Would You Think It's The Steering Gear?
    GT Level Member hammerline81's Avatar
    Apr 2013
    Saskatoon, SK
    Hello people once again...
    So I've been driving around and whenever i turn (left or right) i can hear a clicking sound as my tires rotate and let me proceed with my turn. i figured that my CV joints were shot, so i checked them over, there was no grease anywhere and from what i can see and feel there's absolutely no cracks or cuts in the boots. so i believe i eliminated the CV joints as a problem creating this annoying sound.
    I can turn my wheels left to right and hear this clicking sound as I'm in park. I'm thinking it's the steering gear, but I'm not 100% sure about this. I own 4 vehicles including this 04 GTP and never had a problem like this so i have no idea what it sounds like to wear out steering gears?
    P.S.
    I have a sway bar link that's completely disconnected/broken off the sway bar.
  2. #2 Re: Would You Think It's The Steering Gear?
    gardner,mass
    have someone turn the wheel as you inspect where its coming from
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: Would You Think It's The Steering Gear?
    Apr 2013
    Saskatoon, SK
    i did that and it is the arm that is apart of the steering gears. i guess i dont really know what im replacing when it comes to this. i shouldnt have to get the whole assembly, do i?
  4. #4 Re: Would You Think It's The Steering Gear?
    Apr 2013
    Saskatoon, SK
  5. #5 Re: Would You Think It's The Steering Gear?
    Inner tie rod?
  6. #6 Re: Would You Think It's The Steering Gear?
    Go to a parking lot. Turn the wheel all one way and drive in a slow circle. Then reverse the direction of the tires. If you hear a clicking doing this, then likely it's a CV. They don't have to leak out to wear, they wear all the time.
  7. #7 Re: Would You Think It's The Steering Gear?
    Apr 2013
    Saskatoon, SK
    Alright, I'll try that as well then.
  8. #8 Re: Would You Think It's The Steering Gear?
    Apr 2013
    Saskatoon, SK
    Hey, I did that circle test you suggested, there was no clicking. The only clicking was from turning my steering wheel, I could video tape it today if I have time so you guys can check it out. I'm almost curtain that it would be the steering gear but like I said, I've never experienced this before. Any reasons why the gear would go if this is the case?
  9. #9 Re: Would You Think It's The Steering Gear?
    Apr 2013
    Saskatoon, SK
    UPDATE: It's my steering gear. Clicks when I turn the wheel from left to right, sounds like a grinding. So if anyone that has this happen, do what billboost recomended at first and if it doesn't click doing that and only just turning the wheel, its more than likely the steering gear. I'll post what a 04 GTP needs as far as the options go because there's an option for variable steering and a magnetic speed. Thanks for the advice and help once again guys, Greatly appreciated!
  1. gear set, 4th gear hub, channel plate gouged! help!
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2013, 04:54 AM
  2. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  3. steering gear
    By sweetgtx98 in forum General Tech Discussion
    Last Post: 09-16-2011, 01:19 AM
  4. Steering Gear
    By emoeller in forum Brakes/Suspension/Chassis
    Last Post: 12-16-2010, 12:24 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
