Thread: No brake fluid to rear calipers
Results 1 to 4 of 4
  1. #1 No brake fluid to rear calipers
    Nov 2010
    Bloomington, IN
    On a 94 Grand Prix with 4 wheel disc brakes and ABS, I have no brake fluid coming out of the ABS unit to the two lines that run to the rear calipers. I checked the fuse and it is OK, and there is fluid pressure from the ABS unit to the two lines that run to the front calipers. I suppose pressure to the front is a default status. What prevents pressure from going to the rear? Thanks in advance for any advice.
  2. #2 Re: No brake fluid to rear calipers
    did you open the lines ( or take them off) and push the brake pedal?
    if so you just let a ton of air in the master cylinder and it now needs to be bled.
  3. #3 Re: No brake fluid to rear calipers
    Abs module could be bad. They tend to go bad a lot
  4. #4 Re: No brake fluid to rear calipers
    Are the rear brake hoses collapsing?
  1. Painting Brake Calipers
    By TKoZ in forum Brakes/Suspension/Chassis
    Last Post: 06-06-2011, 12:56 AM
  2. painting brake calipers
    By mk frilla in forum Visual/Body Modifications
    Last Post: 11-10-2010, 08:22 PM
  3. Painting brake calipers.
    By Freebeer187 in forum Brakes/Suspension/Chassis
    Last Post: 08-26-2008, 01:34 AM
