Thread: Spring Rates for lowering
Results 1 to 15 of 15
  1. #1 Spring Rates for lowering
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    So I'm looking into dropping and upgrading the front of my car a little bit. I have been looking at spring rates. For my bonne it is around 140 lbs/in. (don't worry they will fit when I'm done) Looking at DNA spring at 450lbs/in. Is this going to be crazy stiff or is there something odd about there number.
    Thanks
    97 Bonneville SE Not so much a 97 anymore
  2. #2 Re: Spring Rates for lowering
    DNA are definitely not that high of a spring rate. not even close. i bet they are under 200 lb/in and linear.
  3. #3 Re: Spring Rates for lowering
    Nov 2009
    Central Jersey
    That's what I was thinking too. The description says 450 lb/in and I was thinking if any truck springs are that high ha. I'm swaying to a more higher quality spring though. The Bonne is a little heavier and I'm going for a little bit of a raked look.
  4. #4 Re: Spring Rates for lowering
    i would get something like eibach or SSC, to be honest.
  5. #5 Re: Spring Rates for lowering
    Arizona
    Just convert to coil over seriously its like the same price as eibachs. And your Bonneville isn't that much heavier.
  6. #6 Re: Spring Rates for lowering
    Nov 2009
    Central Jersey
    Is this the kit I'd be looking to start out with? summit coil over kit
  7. #7 Re: Spring Rates for lowering
    Arizona
    No start here http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
    Scroll down a couple posts its really easy.
  8. #8 Re: Spring Rates for lowering
    Nov 2009
    Central Jersey
    Boom awesome thank you for not giving me the go look it up on google answer. This look easy peasy. Now for the stupid question. These will ride better than any stock configure drop spring?
  9. #9 Re: Spring Rates for lowering
    most likely. depends how low you go and if you're going to ride the bump stops or not.
    and which spring rates you go with.
  10. #10 Re: Spring Rates for lowering
    Nov 2009
    Central Jersey
    I'm only looking to drop an 1.5 or 2. I don't want to rake it too much and really stress out the front. Now bump stops are the trapezoidal hard foam pieces?
  11. #11 Re: Spring Rates for lowering
    If you want better traction and a raked look..
    http://www.summitracing.com/parts/ai...del/bonneville
    If you do springs etc.. that should just make it all the better.
  12. #12 Re: Spring Rates for lowering
    Nov 2009
    Central Jersey
    Yep I know of the bags too. I don't you know if I want to raise the rear anymore. But I would like to drop the front and add fbodies.
  13. #13 Re: Spring Rates for lowering
    You don't have to raise the rear with them. You can just hold the rear where it is.
  14. #14 Re: Spring Rates for lowering
    Arizona
    That's all I dropped my gxp with coilovers they ride at SSC height but my strut mount has the mounting point a inch higher so at my current ride height I'm still getting 4-5 in of strut travel. And I love the way it Rides
  15. #15 Re: Spring Rates for lowering
    Nov 2009
    Central Jersey
    Very true. Once I tune and see if I blow tires off then I'll throw them in there too ha.
  1. Possible new Hyperco Lowering spring kit
    By rcdino1978 in forum Group Buys
    Last Post: 06-18-2012, 02:39 PM
  2. Lowering spring clearance question
    By DBGP in forum Brakes/Suspension/Chassis
    Last Post: 06-06-2011, 09:27 PM
  3. Spring rates
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 04-10-2011, 10:21 AM
  4. Lowering spring question.
    By 1lowcaprice in forum Brakes/Suspension/Chassis
    Last Post: 02-17-2009, 07:22 AM
