Thread: Front right wheel bearing bad, DIY?
Results 1 to 16 of 16
  1. #1 Front right wheel bearing bad, DIY?
    May 2013
    US
    My front right wheel bearing is bad. The dealer will fix it under warranty with a $200 deductible. Local shops quote between 240-320. The part is only about 130 and was wondering if I could do it myself. I've done my brakes plenty of time before and getting the caliper and rotor off probably sounds like the most involved part which would be no sweat. Is there much more than just talking the bolts off the bearing, taking it off, cleaning any rust and such on the axle, area where it's placed and then put the new one on?
  2. #2 Re: Front right wheel bearing bad, DIY?
    Thats pretty much it.
    All you need is a 35 or 36mm socket for the axle nut and a hammer to whack the axle loose and pop the bearing off.
  3. #3 Re: Front right wheel bearing bad, DIY?
    yup that easy to do, just like you and five finger said.
    tip: put the spare tire on, ( 2 lugs are fine) then lower the car to the ground, then take the axle nut off. i use a breaker bar and a jack handle pipe for leverage.
    unplug the hub before taking the bolts off the hub, then beat it off.
  4. #4 Re: Front right wheel bearing bad, DIY?
    May 2013
    US
    Thanks Looks like I know what I'm doing this weekend.
  5. #5 Re: Front right wheel bearing bad, DIY?
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Yup. If you can do brakes, you're more than halfway there. Total of 4 more bolts/nuts to remove - one of which is the axle nut. Do what Scotty said with the spare. I use a 6' pipe from my wife's hammock frame with my breaker bar to break it loose. If you have problems getting the axle out of the bearing, put the nut back on even with the end of the axle (or put a chunk of 2X4 over the end of the axle), and hit it a few times with a hammer. After you have the bolts out of the hub, use a hammer to pound it out. Hit the wheel holding the lug studs from behind, and it will push it out quite efficiently. Check the knuckle after the hub is out - sometimes there's a metal cover that comes off of the hub and sticks in the knuckle. Good luck!
    Oh - 1AAuto has a GREAT video that shows how to do this job, BTW...Check it out.
  6. #6 Re: Front right wheel bearing bad, DIY?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Make sure to get a SKF bearing, and if you can't find that then MOOG or maybe timkin, nothing chinese unless you want to do it over again in a year.
    also make sure to put the axle nut back on at 118 ft/lbs the correct torque on it goes a long way to keeping your bearings alive.
  7. #7 Re: Front right wheel bearing bad, DIY?
    Jan 2012
    FT Campbell, KY
    Quote Originally Posted by addzradd View Post
    What's your source for SKF? I went to OReilly but their catalog is down for the moment.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  8. #8 Re: Front right wheel bearing bad, DIY?
    Apr 2012
    Goderich, Ontario
    -Paul Walker
  9. #9 Re: Front right wheel bearing bad, DIY?
    Quote Originally Posted by ricksgpgtcolleen View Post
    Napa.
  10. #10 Re: Front right wheel bearing bad, DIY?
    Feb 2010
    Cleveland
    Napa, world auto parts or rockauto
  11. #11 Re: Front right wheel bearing bad, DIY?
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Seems like the passanger hub is always the problem
  12. #12 Re: Front right wheel bearing bad, DIY?
    Florida
    My passenger one is bad too. Lol
  13. #13 Re: Front right wheel bearing bad, DIY?
    May 2013
    US
    So I got the new one on today, was quite a task, also pretty terrifying how bad of shape of the old one was in.
    The old one came off in two pieces. I took the rotor off and one piece of the hub just fell off as soon as the rotor wasn't on. The second piece required a bit of muscle... ended up having to resort to a mallet to get it knocked off. Not sure how my wheel didn't fall off with the shape the other one was in.
    Cleaned it all up, put the bearing on, hooked up the sensors, torqued it to spec and it seems to be good as new. Nice to have a quiet and smooth ride... we'll see if it stops the jolt I mentioned in this thread: http://www.grandprixforums.net/maf-problem-80953.html Fingers crossed!
  14. #14 Re: Front right wheel bearing bad, DIY?
    pa
    I went thru 4 bearings in four months , 3 Timken and 1 moog
  15. #15 Re: Front right wheel bearing bad, DIY?
    St. Louis
    Seems like an afully high failure rate for a Timkin. You are torquing the axle nut to the proper torque, right? If not then the bearing preload is not being set and could wear them prematurely. Seen this happen before so just an FYI.
  16. #16 Re: Front right wheel bearing bad, DIY?
    pa
    Quote Originally Posted by FordMan77 View Post
    torqued them to the specs that the sheet that came with the bearing. 118. since timkin started having their bearings made in china m I haven't heard much good
  1. Front wheel bearing Q
    By bowsox88 in forum Brakes/Suspension/Chassis
    Last Post: 09-19-2011, 11:11 AM
  2. I think I have a bad front wheel bearing-help please
    By dorkfish in forum Introductions/Noob Questions
    Last Post: 04-10-2011, 05:55 PM
  3. Front Wheel bearing on an 06 GT
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2011, 06:33 PM
