Thread: Suspension noise and tire issue
Results 1 to 9 of 9
  1. #1 Suspension noise and tire issue
    Florida
    Need help trying to figure out what I been hearing for awhile in my front end. Happens every time I take off half throttle or more theres like this knockin noise in succession(usually like 2 or 3 little knocks) almost like metal on metal or metal against hard plastic. It happens sometimes too when i put the car in reverse it knocks real quick but all the time when I take off harder then usual.Car has 116k miles and drives fine otherwise. Then part 2 of my problem is my rear passenger tire is lumpy-like on the inner edge and when Im braking,especially from high speeds my rear shimys from that deformed tire, I heard its called "cupped tire", what causes that, and any ideas?
  2. #2 Re: Suspension noise and tire issue
    check your lower engine and tranny mounts, and the tire problem could be alignment related. or you dont rotate your tires. or theres more of a issue with worn parts causing the cupping.
  3. #3 Re: Suspension noise and tire issue
    Florida
    I was thinking a mount too then a mechanic said it could be my sway bar link. That particular tire has not been rotated since I had the car. But will be replacing that tire next week. Will have my suspension rechecked next week.
  4. #4 Re: Suspension noise and tire issue
    could be the sway bar.
    pop the hood, shift it from P to R then to D, while watching the engine, if its jerking back and fourth a lot, the mounts are bad.
    flipping the dog bones can also help calm this jerking around when shifting in and out of gear.
  5. #5 Re: Suspension noise and tire issue
    Florida
    Yea i flipped my mounts in the dog bones already but may upgrade to polys soon since one of the bushings is torn a little and could be what I hear when I shift to reverse. Just wanted a second opinion and other possible culprits. Thanks
  6. #6 Re: Suspension noise and tire issue
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Loose tie rod end, lca bushings, ball joints, subframe bolts or bushings all could be possible culprits too.
    Sent from my SCH-I535 using Tapatalk 4 Beta
  7. #7 Re: Suspension noise and tire issue
    St. Louis
    On my 00 GT the cause of my cupped rear tires is due to the worn out struts/springs. I know they're shot. Cupped both tires on the inner edge. Made it sound like a 4x4 on the highway,lol... That and it vibrated the heck out of the car.
  8. #8 Re: Suspension noise and tire issue
    Florida
    Yea my previous car was an 01 gt and same issue had 4 different cupped tired and i needed a whole host of suspension repairs. So im hoping its nothing more then just lack of tire rotation.
  9. #9 Re: Suspension noise and tire issue
    Florida
    Just an update, turns out that 2 of my passenger side diagonal brace bolts were stripped and allowed the bar to flex whenever I put too much load to the front tires. So mechanic removed the bar and i took a quick drive from low speeds and everything and not a sound plus the car actually pulls better from a dead stop now since theres no more interference . They said I can leave it off but is that a good idea or should i replace the bolts? Dont want to mess up my handling.
  1. tire and suspension suggestions
    By Blue GTP in forum Tires & Wheels
    Last Post: 06-27-2013, 09:10 PM
  2. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  3. Suspension noise.... Is something going bad?
    By kkobberstad in forum General Tech Discussion
    Last Post: 02-28-2013, 09:56 AM
  4. Gee Bob, maybe we should have had that suspension noise looked at?
    By buickman104 in forum Off Topic Discussion
    Last Post: 11-16-2012, 02:36 PM
  5. Tire/suspension/sway bar ??
    By SAXD9MM in forum Brakes/Suspension/Chassis
    Last Post: 05-17-2009, 03:33 PM
