Thread: Question about 06 GXP front and rear brake rotors and pads
Results 1 to 3 of 3
  1. #1 Question about 06 GXP front and rear brake rotors and pads
    Jan 2013
    Mercier, Quebec, Canada
    Hi everybody, I bought a set of front and rear rotors and pads of Amazon. I chose my make and model, and they said they would fit, but nothing fits. The rotors and pads are too small. Can anybody give me a couple of links for some sets of rotors and pads. Also, I heard of a ride and handling package, could this be the source of the mix up in sizes. Thanks
  2. #2 Re: Question about 06 GXP front and rear brake rotors and pads
    Likely there arent right because GXP's have different size rotors and different part numbers for pads than what the amazon site may say.
    Either you can go to a parts store and have them get you the correct factory matching rotors and pads or you can find the correct stuff online.
    From some searching I did a little while back, the 2008 Buick Allure (lacross super) has the same size front rotors but arent drilled, so they should be cheaper.
  3. #3 Re: Question about 06 GXP front and rear brake rotors and pads
    Nov 2012
    Madison
    Front ACDelco 18A2438 Brake Rotor : Amazon.com : Automotive Rear---------Rear Amazon.com: ACDelco 18A2499 Professional Durastop Rear Brake Rotor: Automotive Front pads- http://www.amazon.com/ACDelco-17D921...ype=automotive Rear pads- Amazon.com: ACDelco 17D922CH Disc Brake Pad: Automotive check these against your part#s, they are probably different. These should work, since I copped the numbers from Rock Auto
  1. Need New Brake Rotors/Pads
    By kamposs in forum Brakes/Suspension/Chassis
    Last Post: 06-21-2013, 12:56 PM
  2. Brake Pads and rotors
    By packerfanjc in forum General Tech Discussion
    Last Post: 01-20-2010, 09:49 PM
  3. Brake pads for d/s rotors
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 03:24 PM
