Thread: Another Lowering on Coils Thread
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 Another Lowering on Coils Thread
    Apr 2012
    Bancroft. Ontario, Canada
    Before anybody jump's and says "Search is your friend" I've searched, and I can never seem to find the answer to the question's I've had about dropping my Grand Prix on it's guts.
    I read Randall's write up on his Home Made Coilovers 100000000000 times. And I thought that was going to be the route I was going to take in lowering. But I'm managed to get asking myself, how can I go low, and add a little camber. And then I thought "is there any other coil over option out there (for another platform) that is either a Direct bolt on for these car's or with minor mod's can be installed.
    Only reason I ask that, is I'd like to have a camber plate ontop the strut, and there's really no such thing for a grand prix. I've heard of just making the upper hole in the strut bigger for alignment adjustment, but I don't think that's going to give me the degree's of camber I want.
    So is there another option? That's a bit cheaper than buying a full set made for the w-body platform, Or am I just going to have to make my own set of coil's and make due. I do like the height I've seen some people's car's get by being on coils, and making a set of bag's and buying management isn't in my financial bracket.
    So if anybody has any input on this. It would be very helpful
  2. #2 Re: Getting lowered... Once Again.
    You could go to a local machine shop and have plates made...
    That's how much things happen.
    You could Intrax springs...they still make them, and they drop the car quite a friggen bit. Like, close to 3" after all is said and settled. You'd have to look for them under a Buick Regal...but it's all the same stuff.
  3. #3 Re: Getting lowered... Once Again.
    Apr 2012
    Sorry, but i should have mentioned i'm not planing on use lowering springs. I'd rather have the adjust ability with coils. As for a local machine shop.... The closest thing we have to that is the High school, and all they have is a few Arc and Mig Welder's and 2 machine lathes. And school's been out for a while now.
    I read somewhere that Coils off a Lexus (I can't remember the model, or who said it) fit the gp's with minor mods. But I googled it, searched it everywhere, and I've never come across it.
  4. #4 Re: Getting lowered... Once Again.
    Yeah, I've never heard that before.
    Maybe Dave can shed some more light on it.
    *Drunkie.
  5. #5 Re: Getting lowered... Once Again.
    Apr 2012
    Quote Originally Posted by blueguy View Post
    *Drunkie.
    http://www.grandprixforums.net/coilo...nal-73311.html
    I've been through this quite a few times as well
    As for the Lexus Coilovers. It was Kuntzie (I questioned about it on facebook)
    and Quote "Bc coilovers for a lexus es modified by me for the grand prix"
  6. #6 Re: Getting lowered... Once Again.
    If that's the case...
    My front coilovers for my cobalt were damn near idential to my GP stuff...only thing that would need to be swapped out would probably be the mount as you said...everything else was adjustable and would've probably been a close fit.
  7. #7 Re: Getting lowered... Once Again.
    Apr 2012
    Well as in reading Dave's Coilover Confessional thread. There's mainly 2 types. Full setup or Slip over. Everything is slip over for these car's, but something with a full setup would be badass, which is what i really want. Slip over's only allow the car to go as low as the strut itself allows... Which isn't enough. After seeing KillerSpeed's ZZP coil's nearly maxed out. I just think you could get lower still on static.
  8. #8 Re: Getting lowered... Once Again.
    I'm sure you could.
    The only issue you run into then...is correcting mount/axle geometry to avoid wobble at acceleration and premature mount/axle failure.
  9. #9 Re: Getting lowered... Once Again.
    Jan 2009
    Tallahassee, FL
    How low are we talking? This affects what you can get away with in a setup.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: Getting lowered... Once Again.
    Apr 2012
    How low do you think I can go?
  11. #11 Re: Another Lowering on Coils Thread
    as low as you want.
    but the lower you go, the more work it is.
  12. #12 Re: Another Lowering on Coils Thread
    Jan 2012
    Canada
    as low as you want.
    THIS, when im near bottomed out i can feel my axles beg for mercy.
    Face down axles up
    2001 GTP Special Edition - 3.29's built tranny, Coilovers with agx struts, 04+ seats, 18" Eagle 077's, Ported heads, ported blower, pacesetters, 3.4"
    2004 BMW 325CI with the sport package and the correct amount of pedals.
  13. #13 Re: Another Lowering on Coils Thread
    Apr 2012
    I still have a feeling, that you can get lower than that still, and be able to bring back some of your axle geometry
  14. #14 Re: Another Lowering on Coils Thread
    yeah, raise the motor/trans up with spacers. lose hood space.
  15. #15 Re: Another Lowering on Coils Thread
    Apr 2012
    and what difference will that make? i don't have an intercooler under my blower.. So i've got a bit of space to play with
  16. #16 Re: Another Lowering on Coils Thread
    itll change the axle geometry, allowing you to go lower without screwing it up as much.
    however, going low you're going to have other issues from the get go (like rubbing, scraping, bump stop pounding, etc.). how many "low" cars have you driven? because i hit my bump stops all the time, scrape my bumper all the time, and rub my inner fenders all the time. can you handle that?
  17. #17 Re: Another Lowering on Coils Thread
    Apr 2012
    I owned a semi stanced MK2 jetta... I've driven many slammed, stanced car's, it's nothing new. Just take your time.
  18. #18 Re: Another Lowering on Coils Thread
    Jan 2012
    Canada
    x2 .Im pretty much riding on the bump stops,
  19. #19 Re: Another Lowering on Coils Thread
    this is going to be harder for you to get lower. they dont take to being dumped well.
    to do it right while staying static (do bags....do it) you're gonna have to figure out some shorter strut that you can put on the car before you put the sleeves on. or figure out a coilover from another car that can be worked over to fit, like you said.
    either way, nothing sold for the car will get you what you want.
  20. #20 Re: Another Lowering on Coils Thread
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    I did some searching around for some coilovers off of other cars when my bags were giving me a headache. Its somewhere in my thread I think and I'll go look for it, but I never heard about the lexus ones. I even emailed bc and asked if they could look for some based off of some measurements I took from the mounts and told them it was for a custom project but they didn't search for me. I was also going to just go to the junkyard and checkout all the different cars. There has to be something that'll work and I'd like know myself. Let me go search real quick for my notes to took
  1. Lowered car, I think....
    By Unr3al in forum General Tech Discussion
    Last Post: 03-12-2013, 11:24 PM
  2. The lowered GP
    By dengnath in forum Members Rides
    Last Post: 03-23-2011, 08:27 PM
  3. Lowered...20s?
    By pghtattooer in forum Tires & Wheels
    Last Post: 02-21-2011, 07:33 PM
  4. Needs the car to be lowered?
    By ricez in forum Tires & Wheels
    Last Post: 08-19-2008, 07:17 AM
