Thread: Wire hanging from under car near Passenger Side tire
Results 1 to 8 of 8
  1. #1 Wire hanging from under car near Passenger Side tire
    Mar 2013
    Gulf Coast
    There is a 12 Volt wire hanging from under the car and am wondering where it is from. Mainly so I can figure out what to do with it, there is also a wire hanging from where the license plate is.
    This could be dangerous so I am just figuring out what to do.
  2. #2 Re: Wire hanging from under car near Passenger Side tire
    Near the plate might be the plate light bulbs, can you provide pictures or try tracing them.
  3. #3 Re: Wire hanging from under car near Passenger Side tire
    Did you check them for voltage?
    If you have wires...trace them back, it's as simple as following the wire.
    Dangerous, how?
  4. #4 Re: Wire hanging from under car near Passenger Side tire
    Mar 2013
    Gulf Coast
    I don't know much about cars but that wire could have been anything. Even a wire that controls the ABS system. (in that case that would affect braking)
    Found the problem, the wire broke off the bottom light to the car. Advance Auto said the light only comes in a complete bumper assembly. $100 for that particular part.
  5. #5 Re: Wire hanging from under car near Passenger Side tire
    If you had an ABS issue, you would have been notified by a nice little light on the dash. And ABS only affects braking when you try to lock up the brakes. (not being sarcastic, helping to inform you. BTW the owners manual would have mentioned that about the ABS)
    $100 for ?? a foglight?
  6. #6 Re: Wire hanging from under car near Passenger Side tire
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    Why not just connect it back to wherever it came off of for the light?
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  7. #7 Re: Wire hanging from under car near Passenger Side tire
    Mar 2013
    Gulf Coast
    I can't because the plug is broken on the light.
  8. #8 Re: Wire hanging from under car near Passenger Side tire
    SE Level Member blackgtp95's Avatar
    Jun 2011
    Toledo,OH
    sounds like a trip to the junkyard to get a new connector and possibly light if its not screwed up and then just patch/solder the new wiring in
    pics would still help this thread
  1. Clunking from passenger side tire area
    By DJE in forum Introductions/Noob Questions
    Last Post: 04-21-2013, 07:08 PM
  2. Wire hanging down
    By nik12937 in forum General Grand Prix Discussion
    Last Post: 06-30-2012, 07:01 PM
  3. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  4. passenger side leak
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-22-2009, 11:26 AM
  5. i have a sensor hanging from tire
    By grandprixgt in forum General Tech Discussion
    Last Post: 06-29-2009, 05:59 PM
