2006 Grand Prix Base
I had recently replaced my rear brakes 2 weeks ago. Last week I got the "Low brake fluid" warning and I refilled the reservoir. Yesterday my "Low brake fluid" warning came on again however I went to go check the reservoir and the fluid was still at the fill line. Also, when I hit the brakes hard then the warning light goes off.
Note: In the middle of replacing my Rear brakes, I realized I needed a GM tool to retract the caliper piston however the auto stores were closed when I did it so I used needlenose plyers instead and it worked. Could had I caused a rear leak?
So what do you think? Do I have a brake line leak? or do you think it's a computer malfunction?
Thanks.
