Thread: CV Axle Replacement
Results 1 to 7 of 7
  1. #1 CV Axle Replacement
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    I've had to replace both of my CV Axles over the years. I was wondering if anyone knows of good/better brands that would last longer. I keep having the problem of the cv boot failing and grease slinging up everywhere. It seems to happen with the inner cv boot when it only has 3 ridges/bellows on it. Does anyone know of a brand that has 5 or more bellows on both the inside and outside of the axle? Otherwise I'll just get the warranty replacement and stick with the ones I have. I have looked at the ZZP Axles and they only cost about $50 more for the pair but it seems their axles only have 3 bellows on the inside and outside. Atleast the ones I own now have 5 bellows on the outside and 3 on the inside. Thanks for the help!!
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  2. #2 Re: CV Axle Replacement
    I run napa axles in the 3 pontiac's we have at my house, no problems yet.
  3. #3 Re: CV Axle Replacement
    im also running a napa reman axle. its been over a year easy now. all good so far.
  4. #4 Re: CV Axle Replacement
    Nov 2009
    I'll look into the napa ones, for some reason i can't get their website to load right now.
  5. #5 Re: CV Axle Replacement
    Nov 2009
    I bought the napa ones today. Outside boot has 5 ribs and inside has 3 ribs but hopefully they will do better than the ones I have now that keep failing. A lifetime warranty on something that breaks often and needs to be installed by a mechanic isn't worth it. Though the new ones are lifetime warranty as well, i hope they will work better.
  6. #6 Re: CV Axle Replacement
    PA
    I hope those work for you. I run napa axles as well and haven't had any issues with them. I've also ran stock used axles from Morad with good luck.
    2001 GSE
  7. #7 Re: CV Axle Replacement
    Nov 2009
    I got the other axle in the other day and the outside had 5 ribs and inside had 4 ribs which tells me that they hopefully did enough testing to realize that specific axle (the passenger side front) needed the extra flexability in the inner joint to not fail. These will get installed in a few days, hopefully the last time I gotta do this job.
  1. Axle Seal Replacement [*]
    By Metallistar in forum How To Write-Ups/Tech Tips
    Last Post: 01-21-2012, 09:25 PM
  2. HELP! Really put myself into a pickle (cv axle replacement)
    By Teancum in forum Brakes/Suspension/Chassis
    Last Post: 10-04-2011, 05:29 PM
  3. Axle replacement problem
    By Silver GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 04:35 PM
  4. Axle replacement, DIY?
    By Poil336 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2010, 11:03 PM
  5. Axle replacement.
    By DnaProdigy in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2009, 09:28 PM
